Honda MTF weight?
From what i read in this forum a lot you guys favor the Honda MTF even in your LSD equiped tranny.
But searching the forum doesnt come up with the weight?
I could get the Honda MTF in Malaysia but is it the same formula or blend worldwide?
Did Honda developed their MTF to suite both LSD and non LSD trannies?
So its safe to presume i can use it in my B16B tranny?
Reason i'm asking is i'm currently using Redline 75w90 and its almost 5-times more expensive than Honda MTF.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takashi1978 »</TD></TR><TR><TD CLASS="quote">Reason i'm asking is i'm currently using Redline 75w90 and its almost 5-times more expensive than Honda MTF.
You get what you pay for.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">You get what you pay for..... </TD></TR></TABLE>
Ha! It's never as simple as that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C R Spec »</TD></TR><TR><TD CLASS="quote">how many Honda MTF do you put? (quatity)</TD></TR></TABLE>
^w-t-f mate?
^w-t-f mate?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C R Spec »</TD></TR><TR><TD CLASS="quote">What I really mean is ... how many bottles of HONDA MTF do you guys use in your ITRs?</TD></TR></TABLE>
Each bottle is 1 qt - seems to be the 'industry standard' for transmission fluid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">2.3 qts per refill</TD></TR></TABLE>
The full capacity is 2.2 - and the tranny is not fully drained just by pulling the drain plug and letting gravity do its thing. It will barely take 2qt (and sometimes less), but always buy 3 to be sure. It will pour of of the 'fill' plug when its full.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">I use a friction modifier in my trans. </TD></TR></TABLE>
Completely unneccesary with an OEM torsen diff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">I use a friction modifier in my trans. The one I use is from Jeep, its a 4oz bottle and costs like 5 bucks, thats with 2 quarts of honda MTF. </TD></TR></TABLE>
I'm curious where you got the idea that was necessary.
Haha industry standard is 1 liter per bottle here in Malaysia. So its safe to say i only need to buy 2 bottle and it's enough?
Also what special additives does Honda put in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C R Spec »</TD></TR><TR><TD CLASS="quote">how many Honda MTF do you put? (quatity)</TD></TR></TABLE> until its full, and pooring out the top
(roughly 9 quarts) bahh ha jk
Im not sure if different tranny's take different amounts. I know they shouldn't. However, I went to a local Honda dealership and had a clerk look up the amount and it was 2.7 quarts ( J1 JDM B16A tranny ) of Honda Manuel Tranny fluid (4.25 per quart). I change my tranny fluid every time I do an oil change and it looks to take 2 full bottles and about 3/4 of the third before it starts coming out the excess fluid drain plug
i make it simple.. i keep going until it starts to leak out from filler hole.. i'm not spending time w/ measuring cups.
Completely unneccesary with an OEM torsen diff.</TD></TR></TABLE>
Maybe unecessary but its piece of mind for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">
I'm curious where you got the idea that was necessary.</TD></TR></TABLE>
I have another trans that I use for strictly track that has a clutch type diff, I use it in that and along with quieting(if thats a word) the chatter IMHO it makes the tranny feel and sound better. With my stock trans it also sounds and feels better, when I got the car it had a slight grind into 3rd at high rpms and this additive has seemed to shut it up. Maybe bull **** but it works for me, besides its only a couple of bucks from jeep.
I also have used it in all my Jeeps.
Maybe unecessary but its piece of mind for me.</TD></TR></TABLE>
Its beyond unnecessary - it serves absolutely no purpose, as there's no clutch packs in the diff. I dont think it would be harmful in any way, but if you feel the need to lighten your wallet at each fluid change, then have at it
WoRd, I will.....
</TD></TR></TABLE>WoRd, I will.....
