B16 to 1.8l StrockerKits good idea?
Old Jun 20, 2005 | 04:18 AM
hondaapi's Avatar
Default B16 to 1.8l StrockerKits good idea?
A fiend of mine asked me about a b16 to 1.8l strocker kit.
Do you regard is as a good investment? Any oppinions or ideas what I have to take care about in such cases?
Suggestions are very welcome!
Thanks
http://www.mkr-turbo.de.vu
Old Jun 20, 2005 | 04:52 AM
StorminMatt's Avatar
Default Re: B16 to 1.8l StrockerKits good idea? (hondaapi)
I'm not a big fan of stroking. Remember that the B16A block is shorter than the B18C block. And stroking it to 1.8 liters will result in a poor rod ratio. This will decrease revvability and increase wear. It would be better (and probably cheaper) to increase displacement by upgrading to a B18C bottom end.
Old Jun 20, 2005 | 05:29 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: B16 to 1.8l StrockerKits good idea? (StorminMatt)
Doesnt sound like a bad idea imo. Most get a ls or gsr block and go that route with the stock crank though.
Old Jun 20, 2005 | 06:50 AM
No_Fear's Avatar
i dont believe is a bad idea
another solution ,better sleeves + 85-86mm pistons = less money
Old Jun 20, 2005 | 07:55 AM
Stunna BEN's Avatar
Default Re: (No_Fear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by No_Fear &raquo;</TD></TR><TR><TD CLASS="quote">i dont believe is a bad idea
another solution ,better sleeves + 85-86mm pistons = less money</TD></TR></TABLE>
Add that to a crower or eagle crank
Old Jun 20, 2005 | 09:49 AM
Power Rev Racing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">I'm not a big fan of stroking. Remember that the B16A block is shorter than the B18C block. And stroking it to 1.8 liters will result in a poor rod ratio. This will decrease revvability and increase wear. It would be better (and probably cheaper) to increase displacement by upgrading to a B18C bottom end.</TD></TR></TABLE>
You will not have a bad rod ratio. It will come down to the pistons. You can get a custom piston that will raise the wrist pin on the piston. I just Built a B16 using a LS crank, and B16 Rods. We had JE custom make the pistons for us. YOu can even get it to where you can use LS crank and LS rods. Or GSR crank and GSR rods. I just decided to used the B16 rods though with the LS crank.
CrazyHB
May 13, 2005 12:29 PM
rusteds2k
Aug 17, 2004 02:08 PM
yimmy
Oct 28, 2003 10:48 AM
00 FBP ItR
Mar 19, 2003 01:26 PM
2080EK
Jan 7, 2002 06:09 PM
