Fuel pressure gauge
Old Jun 20, 2005 | 03:04 AM
Jayzeroone's Avatar
Default Fuel pressure gauge
I have a AEM high volume fuel rail and fuel pressure regulator. i recently purchased a gauge to see where my fuel pressure is. now here is my problem the hole that it screwes into on the fuel rail is striped (how it happened i have no idea) is there any where else i can mount it and do you guys know here i can find instructions on how to do so and what i need to do it. thanks for your help
Old Jun 20, 2005 | 05:02 AM
monicle's Avatar
Default Re: Fuel pressure gauge (Jayzeroone)
if the hole is stripped how is the fuel not shooting out of the hole? you could drill and tap another hole in the rail or helicoil it or some crap, however if it were me id replace the whole rail. The last thing i would want it a fire taking out my entire car. screwed up parts have no place under my hood.
Old Jun 20, 2005 | 06:35 AM
kreush33's Avatar
Default Re: Fuel pressure gauge (monicle)
you can screw it into the top of your fuel filter canister under the hood, with the banjo fitting, thats where i put mine.
Old Jun 20, 2005 | 07:03 AM
Jayzeroone's Avatar
Default Re: Fuel pressure gauge (kreush33)
Do you know where i can find instructions on how to do that?
Old Jun 20, 2005 | 08:08 AM
flood's Avatar
I have a picture of a banjo bolt my friend made thats tapped for a shradder valve. Checking the fuel pressure is as easy as checking tire pressure
The valve came off a Ford FI unit.
I don't have the picture hosted anywhere so if you want pics IM me.
Old Jun 20, 2005 | 03:29 PM
kreush33's Avatar
Default Re: Fuel pressure gauge (flood)
all you do is take the bolt off of the top of the banjo fitting and screw your fuel pressure guage in there instead of the bolt.
Old Jun 20, 2005 | 03:41 PM
Jayzeroone's Avatar
It will bolt right up there is nothing in need? Is there any precautions i should consider before doing this? Thanks again for all your help
Old Jun 20, 2005 | 03:59 PM
fasthatchb18c1's Avatar
yeah get a new washer and wrap the FPG in Teflon tape so you dont have leaks
AlxSiR7
Dec 25, 2004 01:19 PM
AgentJam
Oct 26, 2004 04:33 PM
alpha
Jun 14, 2003 07:19 PM
b18cya
Apr 10, 2003 09:24 AM
Accord EX F22
Aug 9, 2001 05:07 PM
