usdm bumper reinforcement bar and air bags
Old Jun 20, 2005 | 12:35 AM
ekim952522000's Avatar
Default usdm bumper reinforcement bar and air bags
hey guys i just installed a jdm conversion and kept the usdm bumper reinforcment bar and was wondering if my airbags will still work in the event of a crash?
also if i buy a jdm srs airbag will the airbag in the jdm steering wheel funtion just like the one in my acura wheel?
i am asking because i thought there were sensors in the front of the car that deploy the airbag?
iv'e been searching for 20 minutes and can't find an answer to there questions thanks for all the help
Old Jun 20, 2005 | 01:27 AM
uNF$@#!'s Avatar
Default Re: usdm bumper reinforcement bar and air bags (ekim952522000)
if you kept the usdm front beam, why would it be any different? you've just changed body panels.
Old Jun 20, 2005 | 11:45 AM
well that's my thinking but i didn't see anything on the front that tells the airbag to go off i was wondering if anyone new what makes them go off
and how about the jdm steering wheel do the airbags work with it
Old Jun 20, 2005 | 02:25 PM
no one knows what makes the airbags deploy?
Old Jun 20, 2005 | 02:35 PM
artifex's Avatar
say it
Default Re: (ekim952522000)
the SRS unit has an impact sensor (accelerometer) that judges the force of impact and sends a signal to the trigger circuit if the force is large enough. the SRS unit is located underneath/behind your car stereo. There aren't any srs-related sensors in your bumper.
as long as the plugs are the same, the steering wheels should be interchangeable. just make sure you disconnect the battery for at least 3 minutes before tampering with your SRS system (per helms manual). you don't want it to deploy while you're swapping steering wheels.
Old Jun 20, 2005 | 06:13 PM
Ill's Avatar
Ill
Default Re: (artifex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by artifex &raquo;</TD></TR><TR><TD CLASS="quote">the SRS unit has an impact sensor (accelerometer) that judges the force of impact and sends a signal to the trigger circuit if the force is large enough. the SRS unit is located underneath/behind your car stereo. There aren't any srs-related sensors in your bumper.
as long as the plugs are the same, the steering wheels should be interchangeable. just make sure you disconnect the battery for at least 3 minutes before tampering with your SRS system (per helms manual). you don't want it to deploy while you're swapping steering wheels.</TD></TR></TABLE>
Ding Ding Ding! We have a winner! Changing the bumper support to JDM will not affect deployment. FOLLOW THE HELMS *EXACTLY* when working on the airbags!! If you deploy it accidentally it can very easily *kill* or *maim* you!!!!! This cannot be stressed enough.
Yes, the JDM wheel airbag will work exactly the same.
Old Jun 21, 2005 | 09:36 AM
thanks for all your help guys i really didn't have any idea how the airbags worked
Old Jun 21, 2005 | 09:43 AM
midwesta's Avatar
the sensors are located under your feet, one in the passenger side and one on the drivers side, unless something changed since 92 and 95.
Old Jun 21, 2005 | 12:01 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (techintegra)
http://www.howstuffworks.com/airbag.htm
Old Jun 21, 2005 | 08:13 PM
that's a cool site
Ayee_drian
12
Nov 2, 2012 06:58 AM
jordanitr
Jul 22, 2007 02:08 AM
98R-1144
May 16, 2003 12:36 PM
Happyman
Mar 4, 2003 02:20 PM
