Busted 99 Ignition after theft attempt, hard to replace?
Old Jun 19, 2005 | 10:55 PM
JoelSiCustoms's Avatar
Default Busted 99 Ignition after theft attempt, hard to replace?
Someone almost stole our 99. Destroyed the ignition cylinder, column looks a little twisted. Thought I would start with the ignition cylinder. Is it even possible to replace the cylinder with it being damaged. Help is much appreciated, thanks.
Joel- SiC
Old Jun 20, 2005 | 06:50 AM
kreush33's Avatar
Default Re: Busted 99 Ignition after theft attempt, hard to replace? (JoelSiCustoms)
Yes it is possible to replace the ignition cylinder, I dont know the extent of the damage though, but you have to take apart your stearing colum to remove it. Helms will show you the way
Old Jun 20, 2005 | 06:45 PM
I have decided just to replace the entire column which is only 100$ anways. I dont think the old cylinder would come out with it being all banged up.
Old Jun 20, 2005 | 07:20 PM
Aphelion's Avatar
Default Re: (JoelSiCustoms)
Good idea, if it's only $100. Probably not worth the hassle.
Old Jun 20, 2005 | 08:49 PM
Backk InTheDA's Avatar
I hate everything
Default Re: (Aphelion)
Yeah, i was wondering if the cylinder could be replaced as well, good info guys.
Old Jun 20, 2005 | 10:00 PM
ErrDizzle's Avatar
Can't you order a new one from the dealer and it would already be keyed for your original keys?
Old Jun 21, 2005 | 11:07 PM
Well. a new cylinder with key is 260$. A used cylinder with key is 75$. Might as well just put the whole column in. I dont want to mess with the cylinder.
skwigelf
Sep 30, 2015 08:23 AM
ekkscott
Honda Civic (2001 - 2005)
Jun 6, 2012 02:45 PM
acuraTboo
Honda Civic (2006 - 2015)
Dec 19, 2011 07:04 AM
BxBomber712
Feb 5, 2010 11:39 AM
