motor cutting off
Old Jun 19, 2005 | 09:16 PM
Xxcivic99xX's Avatar
Default motor cutting off
I was driving today and my motor just shut off. then i pulled over and it started right back up. This is off a B16a2
I also wanted to know how do you drain the bluid fluid. I need to change
Old Jun 19, 2005 | 09:53 PM
snowseeker's Avatar
Default Re: motor cutting off (Xxcivic99xX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xxcivic99xX &raquo;</TD></TR><TR><TD CLASS="quote">I was driving today and my motor just shut off. then i pulled over and it started right back up. This is off a B16a2
I also wanted to know how do you drain the bluid fluid. I need to change </TD></TR></TABLE>
Loose iginition wire somewhere, bad ground somewhere.
Bluid fluid is in the back by the blinker fluid. There is a little drain plug in the bottom under the bumper cover.
Delicieuxz
Apr 12, 2018 09:08 PM
whiteboy03si
Mar 7, 2007 08:03 PM
TommyV
Honda S2000
Apr 14, 2004 08:53 AM
DeDonDeRosa
Jun 9, 2003 11:58 AM
sackdz
Jun 26, 2001 04:17 AM
