What is the shortest Short-Throw Shifter?
Old Jun 19, 2005 | 08:59 PM
atomicarmy's Avatar
Default What is the shortest Short-Throw Shifter?
For people that have tried several short throw shifters. What is the shortest Short-shifter? (Meaning Shifting distance)
Thanks For supporting my nub-ness
Old Jun 19, 2005 | 09:06 PM
atomicarmy's Avatar
Default Re: What is the shortest Short-Throw Shifter? (atomicarmy)
Old Jun 19, 2005 | 09:45 PM
Cherchez La Ghost's Avatar
Cut your shift lever
Old Jun 19, 2005 | 10:12 PM
atomicarmy's Avatar
Default Re: What is the shortest Short-Throw Shifter? (Lekz)
lol anything else?
Old Jul 10, 2005 | 08:27 PM
Hatchamaback's Avatar
I love my skunk2 short shifter and 440 gram ****.
Old Jul 11, 2005 | 04:53 AM
91civicDXdude's Avatar
cut a stock shifter below the pivot point and extend it to the desired distance and weld it back together. you can make it as short as you want
Old Jul 11, 2005 | 05:54 AM
tgreaves's Avatar
Default Re: (91civicDXdude)
I have tried out alot of short shifters and the best one that I have found is the one that im using.. Some $8 piece of **** from ebay..
Old Jul 11, 2005 | 07:40 AM
bosco500's Avatar
Default Re: (tgreaves)
cut it
Old Jul 12, 2005 | 02:59 AM
moomakudafi's Avatar
Default Re: (bosco500)
run a stock shifter with some stiffer bushings. short shifters (really short ones) causes something in the trans to mess up. im not exactly sure what it is but a number of the cars i worked on at my job had tranny problems because of em. my boss said its similar to having a car dropped on the ground and the axles having to bend and stretch, causing them to tear a boot or break. it kinda makes sense to me cause the linkage is only so long, and when you extend the bottom of the shifter, the linkage length gets shorter. my boss, who is also my good friend, knows his **** and i believe him. just figured i share with yall
Old Jul 12, 2005 | 03:00 AM
Default Re: (moomakudafi)
oh yea, the shortest one i had was a DC sports.
Old Jul 12, 2005 | 03:41 AM
bosco500's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moomakudafi &raquo;</TD></TR><TR><TD CLASS="quote">run a stock shifter with some stiffer bushings. short shifters (really short ones) causes something in the trans to mess up. </TD></TR></TABLE>
In all my years of racing, I have never heard or seen such. Shortening of the rod, does not change the linkage length. It changes the shifting length only. There is nothing changed from the bottom of the shifter to the trans.
Old Jul 12, 2005 | 06:19 AM
jdm123's Avatar
B&M
Old Jul 12, 2005 | 06:27 AM
egsleepercivic's Avatar
It is because when people get short shifters they think they have to shift supa fast, but in reality if you shift like a normal person and have a short shifter you will actually be shifting faster and wont tear **** up
Old Jul 12, 2005 | 09:07 AM
projectTeG's Avatar
i like the b&m, but the shortest one i ever saw was the str shifter(dont think they are made anympre)....that thing had a really short throw
Old Jul 12, 2005 | 11:21 AM
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bosco500 &raquo;</TD></TR><TR><TD CLASS="quote">
Shortening of the rod, does not change the linkage length. It changes the shifting length only. There is nothing changed from the bottom of the shifter to the trans.</TD></TR></TABLE>
i was refering to the length below the pivot on the shifter. when that is longer than stock, it shortens throw and changes the angle on the linkage. hope im not confusing anyone, but the geometry of the situation makes sense to me
Old Jul 12, 2005 | 05:03 PM
hayabusa160's Avatar
the twm one is pretty damn short. not the classic version but the short version.
i had the classic and the throws were close to what a s2000 were not bad i liked it.
Old Jul 13, 2005 | 01:49 AM
michael O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moomakudafi &raquo;</TD></TR><TR><TD CLASS="quote">i was refering to the length below the pivot on the shifter. when that is longer than stock, it shortens throw and changes the angle on the linkage. hope im not confusing anyone, but the geometry of the situation makes sense to me</TD></TR></TABLE>
It makes sense but I dont see how that could screw anything in the transmission up. The throw and angle on the linkage shouldn't be a problem.
Old Jul 13, 2005 | 03:10 AM
Joker1's Avatar
I heard they tear up the tranny too...But I just thought it was cause people are shifting too fast before the clutch is all the way in
But, I have a Skunk2 short shifter and Love it!!
Old Jul 13, 2005 | 04:47 AM
cutting the top of the shifter off doesnt really shorten the throw it just changes your leverage.
Old Jul 13, 2005 | 05:19 AM
RYANR1's Avatar
why don't you buy every short shifter and tell us what has the shortest throw... then we'll all go buy it
Old Jul 13, 2005 | 05:37 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">cutting the top of the shifter off doesnt really shorten the throw it just changes your leverage. </TD></TR></TABLE>
Correct, by by changing leverage you can change the speed at which the shift rod moves thus reducing the distance you need to move it..
If you want to try making a short shifter then cut the part off of the bottom of the shifter and add some length to it, that will also change the leverage and make the throw shorter..
Old Jul 13, 2005 | 09:30 AM
Pure Sol's Avatar
twm....
Old Jul 13, 2005 | 09:35 AM
tgreaves's Avatar
Default Re: (Pure Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pure Sol &raquo;</TD></TR><TR><TD CLASS="quote">twm....</TD></TR></TABLE>
Old Jul 13, 2005 | 10:17 AM
chiman72's Avatar
buy a b&m, trust me its worth the money. as far as short shifter busting the tranny sometimes they can mess up the syncros because your shifting to fast for the tranny to react to your clutch movement and such( hard to explain) I saw it happen on a 89 crx si
Old Jul 13, 2005 | 01:17 PM
slomofo's Avatar
GDD Member
Autozone's generic brand short shifter and DC's shifter are the shortest I've had, i'm currently using the autozone cuz the shift arm is stock length, but the throw is short and the DC arm is just too damn short.
