voltage regualtor location
the problem is that when the car runs, the voltage is around 12.0 nad when i shut it off or stall, it instantly falls to around 9.0 or even lower. So in order to strat my car , i need to jump it everytime i turn the key.
Sounds like it could be a battery. Go to autozone and have them run the tests on the alt and batt. Could be the batt not holding a charge, or it could be the alt not charging.
Neil
Neil
New battery and new alternator put in about 3 weeks ago. I checked the connection on the ground wire that bolts to the alternator, nad it seems to be melting away hte rubber outer cap. im gonna go clean up the connection tomorow. any other ideas?
BIG_WILL
Nov 16, 2008 07:06 PM
hondastrtracr
16
Jan 27, 2008 09:16 PM
