B and D series parts.
99 civic si shifter linkage, with shifter- 120 shipped or 100 picked up.
99 civic si speedo sensor- 50 bucks picked up
99 civic si slave cyl, with clutch hardline and brackets- 35 picked up
99 civic si differential, no ring gear- 50 picked up.
b16 skunk2 intake manifold, has been tapped for direct port n2o, but can be pluged up with 1/8 npt allen head plugs- 150
b16 str intake manifold, carbon fiber inserts, also tapped for direct port n2o, also has iac, iat, welded shut- 450 obo
b16 head complete. 500
msd 7al-2, 4cyl box. 350 (i have 2 of these)
msd coil- 35. (not the shitty blaster coil)
b series obdo distributer-150
chipped pr3 ecu- 150
b series oil pans. 40 obo, 2 of them are tapped for turbo drain lines.
90-91 integra wire harness- 75 each (have 2 of these)
88 crx radiator, with fan- 100 picked up.
88crx crossmember with "torsion" bars- 75 <--shipped
90 teg crossmember- 75 obo. <--shipped
thermal stainless cat back 2.25 inch fits CRX. 300 obo
hollowed out cat-25 obo
dc sports 4-1 header, with thermal wrap, minor dings, NOT FLATEND, could use a paintjob. its alittle old and rusty looking. bolts up to stock cat.- 150 obo.
b series crank pully's- 20 each
d series crank pully's- 10 each
d series clutch- 30
d series "T" bracket -15 each
d16z6 intake manifold's -25 each
d&b series alternator's -35 each
b series thermostat housings & water tubes - 20 each.
b series speedo sensor's- 50 each.(mechanical and electrical)
bseries timing belt cover's(i have 6 lower's/3 upper's)-20 each
bseries flywheel- 10+shipping.
Modified by Dturbocivic at 12:29 PM 6/21/2005
d series clutch- 30
Dave I might need these parts. Throw me a good price.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic »</TD></TR><TR><TD CLASS="quote">99 civic si shifter linkage, with shifter- 120 shipped or 100 picked up.
d series clutch- 30
Modified by Dturbocivic at 12:29 PM 6/21/2005</TD></TR></TABLE>
d series clutch- 30
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by june »</TD></TR><TR><TD CLASS="quote">Bump for some parts I need and will pick up.
when you coming to get them??
</TD></TR></TABLE>when you coming to get them??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiclxb16a »</TD></TR><TR><TD CLASS="quote">where is "on the bus" in pa?</TD></TR></TABLE>
19440
19440
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiclxb16a »</TD></TR><TR><TD CLASS="quote">how much for one of those b series crank pulleys shipped to 18301?</TD></TR></TABLE>
25. let me know.
25. let me know.
