help with tranny fliud!
Old Jun 19, 2005 | 05:45 PM
ecovillain's Avatar
Default help with tranny fliud!
so i went to change the fluid in my tranny (89 dx cable tranny). the fill bolt wouldnt budge, so i undid the drain and drained everything. i tried filling through the breather on the top by the reverse sensor, but that was super slow (its a really small hole). so i took out the vss and tried putting my funnel in there, but now NOTHING is going into the tranny.
how the hell do i get the fluid to go in there?
please help! my car is stuck with a funnel in it!
Old Jun 19, 2005 | 06:14 PM
ecovillain's Avatar
Default Re: help with tranny fliud! (ecovillain)
bump someone help me out here!
Old Jun 19, 2005 | 06:49 PM
Crx Jimmy's Avatar
try to get the fill plug open, it should be a 17 i think, put a pipe on it if you have to it should come off quite easily though
Old Jun 19, 2005 | 07:40 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: help with tranny fliud! (Crx Jimmy)
I had to use a 17mil wrench and a cheater pipe to get the damn thing off last time...
Old Jun 19, 2005 | 07:49 PM
ServiceAdvisor's Avatar
Pull the starter off. There's a 3/4" bolt that you can remove and drop some fluid in if your out of options. I actually find it easier to fill this way, but I'm just wierd I guess.
Old Jun 19, 2005 | 07:50 PM
ecovillain's Avatar
Default Re: help with tranny fliud! (LSVTEC 91 Civic)
i tried the bar on the fill bolt...not doing anything. the bolt just started to strip itself.
the car is back on the ground now, and my question is this:
why wouldnt the oil flow freely into the tranny if i pour it into the breather hole or the cable vss mountpoint?
Old Jun 19, 2005 | 08:33 PM
Malgerus's Avatar
The tranny fluid should fill through the VSS. I use the fill plug on the side of the tranny, and if I want to overfill a bit I put it in the VSS hole. Works for me.
Old Jun 19, 2005 | 08:38 PM
insomniac791's Avatar
Make sure you are useing a 6 Point wrench it will not strip as easy as a 12 Point!
Old Jun 20, 2005 | 09:08 AM
ecovillain's Avatar
Default Re: (insomniac791)
but why wouldnt it go in through the vss or the breather hole? either im filling it improperly or my tranny is fucked or i dunno what....
ef dino
Dec 16, 2006 06:42 PM
.one lane
May 2, 2006 05:38 AM
H22A4Me
Jan 27, 2006 07:55 PM
vmm
Jun 25, 2004 08:54 PM
showstopper
Aug 26, 2002 09:06 PM
