AT won't go into gear after swap
Old Jun 19, 2005 | 02:59 PM
16bit_Villain's Avatar
Default AT won't go into gear after swap
So I swapped a D16Z6 that was previously mated to a manual into my car and hooked it up to my B7 auto tranny.
The car also isn't going into gear at this point, even after making sure that the shift cable is properly attached. It shouldn't need to be adjusted because the mounts for the transmission are all the same. When I try to put in in any gear the speedo reads between 5 and 10mph and I can hear a slight tapping/grinding noise... like two gears are barely brushing against each other... every so often.
Anyone ever have this problem? I've gotten the car to more or less run right... now I just need to make it move.
Oh, and I suppose this is going to be my introduction here on Honda-tech. (Been a member for awhile, just never posted.) You guys seem like a nice enough bunch and look forward to contributing to the community wherever I can!
Old Jun 19, 2005 | 04:12 PM
hatchi's Avatar
Default Re: AT won't go into gear after swap (16bit_Villain)
did you put on the torque converter correctly??
Old Jun 19, 2005 | 10:40 PM
It can only go in two ways right?
I wasn't actually there when my freind put the tranny back on the new engine, but I can't imagine that he would have done that.
I did get it to go into gear once today after putting some tranny fluid (until full) and it was going in reverse just fine until I tried to put it in drive and it slipped back out again.
Any clues anyone?
clekers
Aug 30, 2009 10:59 PM
85_305
Honda Civic (2001 - 2005)
16
Jun 6, 2009 05:29 AM
85_305
Transmission & Drivetrain
Jun 5, 2009 08:35 PM
DrZaius
Apr 24, 2005 06:53 PM
cxSHOE
14
Dec 30, 2003 06:14 PM
