forged internals
Old Jun 19, 2005 | 02:46 PM
ecl-ricochet's Avatar
Default forged internals
I am looking to find out what some affordable yet good forged internals for a d16z6. I am looking to make it run 22-30 psi. I am looking for the typical stuff pistons, rings, rods.....you know normal. Stock bore.
Thanks in advance.
Old Jun 19, 2005 | 03:17 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: forged internals (ecl-ricochet)
my 2 favorites.
JE and Crower
Old Jun 19, 2005 | 03:20 PM
WickidClown's Avatar
Default Re: forged internals (boostedcivicsir)
crower all the way
Old Jun 19, 2005 | 03:23 PM
z6's Avatar
z6
vitara
Old Jun 19, 2005 | 08:09 PM
Mr. JDM-GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">my 2 favorites.
JE and Crower</TD></TR></TABLE>
Ditto
Old Jun 19, 2005 | 08:23 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 &raquo;</TD></TR><TR><TD CLASS="quote">vitara</TD></TR></TABLE>
For pistons, yes. Cheap and reliable. For rods, either Eagle with upgraded rod bolts or Crower would be the best choices, and new piston rings from either of the aforementioned manufacturers.
Old Jun 20, 2005 | 06:43 AM
Default Re: (Archidictus)
The vitara pistons will fit the stock bore of the d16?
Old Jun 20, 2005 | 07:01 AM
jolt-tsp's Avatar
Default Re: (ecl-ricochet)
Where do you go about getting Vitara pistons on the cheap? I checked ebay, don't know where else to check
Old Jun 20, 2005 | 08:05 AM
flood's Avatar
Default Re: (jolt-tsp)
30psi!?!?
Wow, thats alota boost.
I take it that the block has to have some work done to accomodate that much boost. Does it require a new block or just a block girdle?
Old Jun 20, 2005 | 08:07 AM
civiccpedx's Avatar
Default Re: (flood)
yeh 30 psi is quite a bit of boost, i would sleeve the block and use top of the line all around, gonna take a lot of work and tunning
Old Jun 20, 2005 | 09:31 AM
EKB18BPR3's Avatar
i got eagle rods and cp pistons and havent had any problems with them.
Old Jun 20, 2005 | 09:34 AM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp &raquo;</TD></TR><TR><TD CLASS="quote">Where do you go about getting Vitara pistons on the cheap? I checked ebay, don't know where else to check</TD></TR></TABLE>
Autozone and such, my man .
tony n.
May 1, 2007 05:15 AM
clayton bigsby
Feb 11, 2007 04:15 PM
turbo_b16_ex
Nov 13, 2005 02:00 PM
Chillinit
Apr 24, 2005 09:04 AM
ntegls
Feb 22, 2004 06:11 PM
