Oil Pump Gear / Oil Pump?
Prodrive ? Z10 out? is the type-r pump better than the gsr? .....i searched the web but couldnt find any places selling these......
edit : https://honda-tech.com/zerothread?id=67540
nevermind. next time i'll search "prodrive" instead of "pro drive"
[Modified by immortal, 10:02 PM 2/11/2002]
If I remember correctly, the Toda is just a strengthened stock unit.
Anyone have info on the ProDrive? I'm curious....
ITR and GSR have the same part number. 15100-P72-A01.
Another option is the Endyn modified oil pump. They port out the housing, reshape the exit port and install a different spring and relief valve.
On my B20, I see a constant 30psi at idle, and it never goes above 90psi. At 3000rpm cruising, it's 80psi steady.
This is with fresh Honda 5w20 oil and OEM Honda oil filter, BTW.
it is just a strengthened stock sized unit.
However, the Prodrive unit does NOT fill all B series oil pumps. It does not fit in my 95 GSR housing, it's too small. However, it is known to fit all B20 housings, ITR housings, and other years of the GSR. Apparently, Honda somewhere switched the housing sizes internally, with no part number change.
db1love
Dec 8, 2010 11:27 AM
