gsr + blox intake manifold + CAI
i wanted to know specifically about the blox intake manifold shape and position.
as we all know, the stock gsr IM is flip sided compared to LS/ITR. which means that the CAI that u purchase has to be shaped so it inserts into the TB and bends at the right positions.
now if u throw a blox IM in the mix.... would i need to use an ls/ITR cai, or a gsr cai, or wat? (fitted onto a gsr)
hope i make sense!
hope i make sense!
i soon will have the blox intake manifold installed in my car, and you will need a LS/ITR intake because the intake inlet sits higher. Thats why i sold my gsr CAI and will use a ITR stock intake arm for temp use till i get more money to purchase a new intake. I know it does suck cuz i already bought an intake and now i need a new one.
Use the ITR application where possible. If there's no difference b/w the ITR and LS apps, then use either.
I've test fitted my stock GS-R intake arm on my skunk2 manifold before. It hits the strut tower bar and doesn't quite line up with the filter at the stock airbox.
It might. I wouldn't rule it out. It may depend a lot on the filter length and diameter because that will limit how much you can angle the intake pipe down to clear the strut tower bar.
after searchign more...
the skunk2/blox IM are both flipped the SAME WAY UP AS itr/ls
which means, yes, i will need itr/ls intakes etc.
no point doing this now. not worth the trouble to switch intakes + trouble of installing and fitting with TB, and other tidbits.
yeah you would need an ITR cai, 3". the ls intake is 2 3/4". i have the blox on my gsr with a short ram and its nice. you need the ITR *throttle cable and *bracket, as well as a *spring from a d series throttle body to put on gsr TB. wish i had pics, my set up looks sweet. the parts alone only cost about $50
*parts
*parts
what throttle body are u using?
another question. if using the blox/skunk2 IM and using stock gsr throttle body.... will the ITR intake fit into the gsr throttle body?
u made mention of itr being 3" and ls being 2 3/4". does that mean if i use the GSR tb... that the 3" ITR intake will not fit on/connect on? i dont know how the intake arm fits into the TB
racekar
Jul 18, 2005 06:37 PM
