rear disk help...
Ok, i bought a 92 Si h/b parts car and it's got rear disk. my other car is a 95 CX with drum. I want to swap the disk over.
will i need to change the master cylinder seeing how the parts are coming off a same gen civic? i hear alot of people talking about using the MC, but they swap teg brakes. I'm lost.. and would like to swap within the next couple weeks.
what else will i need? brake assembly, trailing arms, ebrake cables... i forget what else.. any help would be good. yes i did search but didnt find anything about civic - civic swap
Since the Si came with rear discs, just swap over the whole trailing arm assembly with brake lines, ebrake cables, and prop valve. I am not sure if the Si has a 13/16" or 7/8" MC. If it has the 7/8" swap it over, your CX already has a 13/16" MC. So basically swap everything over since it will all bolt in.
...Baker
Mar 29, 2006 07:37 PM
servion
11
Aug 13, 2003 10:34 AM
