wheel cylinder replacement - 97 accord!
Old Jun 18, 2005 | 08:28 PM
GroundZer0's Avatar
Default wheel cylinder replacement - 97 accord!
Alright, not really happy about this, but i was bleeding my brakes and i broke a nipple off of the wheel cylinder (great more air in the lines).
I cant remove the broken piece, or dont know of any good ways.. and i heard i could remove the wheel cylinder.. i know you have to take off the drum cover, then the shoes, but im not sure how to take off the shoes / how complex it is, and once i have them off, how complex they are to keep together and put back in..
so once i have the shoes off, how do i take the wheel cylinder out / replace it and install and new bleed stem.
I have to move in less than a week and i need to get this done.. problem is, ill be driving around 1400 miles. ANY help would be APPRECIATED!
I could get this done at a shop, but i know a little about cars, and i CANT afford an arm and a leg right now. please, leave me any info!
Also, if you want to email me further instructions / pics :
d1giPhux@gmail.com
Thank you so much!
Old Jun 19, 2005 | 05:56 AM
GroundZer0's Avatar
Default Re: wheel cylinder replacement - 97 accord! (GroundZer0)
bump! NEED HELP
Old Jun 19, 2005 | 07:46 AM
Chiovnidca's Avatar
You dont have to take the shoes off.
Old Jun 19, 2005 | 08:11 AM
GroundZer0's Avatar
so what all do i need to take off? what is the best way to take the drum cover off, does the car need to be in neutral. Its an auto btw =/
Old Jun 19, 2005 | 08:35 AM
deserthonda's Avatar
removing wheel cylinder is a piece of cake......
remove the wheel. drum should come right off there is nothing holding drum once wheel is off except rust maybe if drum won't come off easily, spary wd40 in the center where it slides over the hub let sit a bit ..if really badly rusted there are 2 holes in drum where you can screw in 2 8 mm bolts screw them in till drum pops off......Once drum is off remove the brake line at back of wheel cylinder 10mm use a line wrench make sure not to strip it,,, remove the bolts 10mm wrench holding cylinder in, get a screwdriver push in one side of cylinder piston to come away from shoe then the other side and voila' cylindr is off no need to remove shoes
Old Jun 19, 2005 | 09:14 PM
GroundZer0's Avatar
see what happened was i broke the bleeder screw, what do you think the easiest way to fix this will be, to replace the wheel cylinder? arg.. thanks, i dont think im gonna have time, ill call some shops and see how much they want to rape me for. $$
dresslkr
17
Feb 24, 2017 08:13 PM
Gotrek
Nov 19, 2010 04:41 PM
Milano97
Oct 27, 2006 10:28 PM
dclub01
Aug 29, 2003 09:50 PM
MugenHonda
Jan 21, 2003 08:06 AM
