bike problems 93 f2
Old Jun 18, 2005 | 07:06 PM
92hatchb18's Avatar
Default bike problems 93 f2
bike is bogging at about 7500 rpm's sometimes it won't do it in 1st and second but it always does it when I get to 3rd also I keep having battry problems 2 new batterys in a week they won't stay charged thanks for your help
Old Jun 18, 2005 | 11:54 PM
Matt Groove's Avatar
Default Re: bike problems 93 f2 (92hatchb18)
i've had a lot of problems with my f2 and it's a 92.. before the bike would just turn off and most of the time it wouldn't start or after i start it, starting it up again it would struggle. I have a new battery and i kept it charging always.
I took it to a shop, turns out there were a lot of wiring issues and something with the starter relay. Now the bike runs fine, but i do get that bogging problem too, funny thing is the other shop i took it too said they "rebuilt" my carb
save some money and return a battery, you might be wasting money!
Old Jun 19, 2005 | 11:43 AM
92hatchb18's Avatar
Default Re: bike problems 93 f2 (Matt Groove)
it could be wiring i guess
Old Jun 19, 2005 | 12:46 PM
Rhino-RR's Avatar
Obviously a charging problem..Could be a R/R,loose wire,Jetting problem (carbs)..Give us more information on your bike please,and we might be able to sort it out.
Any mods on this particular bike?
Old Jun 19, 2005 | 05:19 PM
92hatchb18's Avatar
Default Re: (Rhino-RR)
stage 3 jet kit, k&n filter, full micron exhuast thats pretty much it it has no guages except tach, all lights not hooked up bike was laid down
Old Jun 20, 2005 | 04:54 AM
cbrman's Avatar
Default Re: (92hatchb18)
Stage 3 jet kit is setup to use individual filters so either it is not a stage 3 or it you are using the wrong filter(s) as you should have 4 individual filters one for each carb. I would say you want to have your voltage regulator/rectifier checked out. It could also be a wiring harness issue.
FYI: If you need another harness I have one still attached to the spare 94 engine in my garage.
Steven
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchb18 &raquo;</TD></TR><TR><TD CLASS="quote">stage 3 jet kit, k&n filter, full micron exhuast thats pretty much it it has no guages except tach, all lights not hooked up bike was laid down</TD></TR></TABLE>
Old Jun 20, 2005 | 06:38 PM
92hatchb18's Avatar
Default Re: (cbrman)
still has air box and it has stage 3 jet kit with k&n stock style replacement I guess it might be wiring since everything that isn't needed is not hooked up and zip tied out the way I have no idea
I NEED HELP PLEASE
Modified by 92hatchb18 at 3:56 AM 6/21/2005
Modified by 92hatchb18 at 4:01 AM 6/21/2005
Old Jun 20, 2005 | 06:39 PM
92hatchb18's Avatar
I got harness with my old engine whats wrong with the 94 engine you have also now the bike only wants to idle and it's really ruff cuts off and doesn't want to start
Old Jun 21, 2005 | 01:43 PM
92hatchb18's Avatar
anyone please help me
Old Jun 21, 2005 | 03:31 PM
turbo_smallblockchevy's Avatar
common honda problem, replace the rectifier. about 100 bux off ebay. the rectifier is under the right side tail fairing.
Old Jun 22, 2005 | 07:01 PM
92hatchb18's Avatar
Default Re: (turbo_smallblockchevy)
what does it look like I prob have one in my spare parts box
Old Jun 23, 2005 | 05:33 PM
92hatchb18's Avatar
took it to the shop today
1995integrals
Honda Motorcycles
Jun 11, 2010 02:17 PM
Xentropa
Honda Motorcycles
Jan 2, 2009 04:28 AM
Boughetto
Honda Motorcycles
12
Jan 26, 2005 01:12 PM
ShagginJet
Honda Motorcycles
Jun 2, 2004 05:05 PM
LANDMARK23
Honda Motorcycles
Jan 19, 2003 12:49 AM
