(searched) help with adjusting SiR headlights (EK)
Old Jun 18, 2005 | 05:56 PM
Spoon98Hatch's Avatar
Default (searched) help with adjusting SiR headlights (EK)
Problem solved
Modified by Spoon98Hatch at 9:42 AM 6/19/2005
Old Jun 18, 2005 | 07:30 PM
dawrenn's Avatar
Default Re: (searched) help with adjusting SiR headlights (Spoon98Hatch)
Did they come like that? My Type R's are fine: No adjusting.
Old Jun 18, 2005 | 07:36 PM
Default Re: (searched) help with adjusting SiR headlights (dawrenn)
yep. I haven't touched them, just installed them.
Old Jun 18, 2005 | 07:37 PM
dawrenn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon98Hatch &raquo;</TD></TR><TR><TD CLASS="quote">yep. I haven't touched them, just installed them. </TD></TR></TABLE>
Damn that sucks. I dont know what to tell you dude. I wish you luck.
Old Jun 18, 2005 | 07:39 PM
were yours brand new or used?
Old Jun 18, 2005 | 07:40 PM
dawrenn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon98Hatch &raquo;</TD></TR><TR><TD CLASS="quote">were yours brand new or used?</TD></TR></TABLE>
Brand New, They were $500 shipped
Old Jun 18, 2005 | 07:43 PM
ouch mine were $315 shipped brand new with wiring harness for city lights. I want CTR's now If anyone is selling some, let me know
I figured for brand new headlights they would be perfect.
Old Jun 18, 2005 | 07:46 PM
dawrenn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon98Hatch &raquo;</TD></TR><TR><TD CLASS="quote">ouch mine were $315 shipped brand new with wiring harness for city lights. I want CTR's now If anyone is selling some, let me know
I figured for brand new headlights they would be perfect. </TD></TR></TABLE>
I had to buy the city light sockets and wiring harness seperate.
I would think that to. I am sure you will be able to fix the problem, Just sign up for different forums and you will be able to get an answer. Thats what I do. I am a member of 7 car forums total.
Old Jun 18, 2005 | 09:59 PM
.:cesar:. ELUSIVESIR's Avatar
I leveled my headlights a couple of times so here is what you have to do:
There are obviously four bolts that hold your lights in place, the (2) on the radiator support, the one attahced to the bumber support and the one next to the fender. First, put your headlights on and secure the bolts on, but don't tighten them all the way. Next, tighten down the one next to the fender while checking the level on the headlights. Now, tighten the one on the bumper support and check the level at the same time, get it as secure as possible and then secure the ones on the radiator support. Once you've done this you should be good, but if your lights are still off, try to rotate the adjusting wheels or check how secure your bulbs are on the inside. If you need anymore help let me know.
Old Jun 18, 2005 | 10:09 PM
EliteCivicEK's Avatar
Default Re: (searched) help with adjusting SiR headlights (ELUSIVESIR)
yea that worked for my aftermarket ones i have on when i installed them awhile back.. but i just used the adjusting wheel to fix all that
Old Jun 19, 2005 | 05:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELUSIVESIR &raquo;</TD></TR><TR><TD CLASS="quote">I leveled my headlights a couple of times so here is what you have to do:
There are obviously four bolts that hold your lights in place, the (2) on the radiator support, the one attahced to the bumber support and the one next to the fender. First, put your headlights on and secure the bolts on, but don't tighten them all the way. Next, tighten down the one next to the fender while checking the level on the headlights. Now, tighten the one on the bumper support and check the level at the same time, get it as secure as possible and then secure the ones on the radiator support. Once you've done this you should be good, but if your lights are still off, try to rotate the adjusting wheels or check how secure your bulbs are on the inside. If you need anymore help let me know.</TD></TR></TABLE>
I'll try this and let you know
I do remember when I installed them I put the top 2 bolts in first. I didn't tighten them but this could still be my problem.
Edit: I fixed it. remounting the headlight didn't work cause then it wasn't flush with the fender. I just used the other adjuster **** and now they're good.
Modified by Spoon98Hatch at 9:41 AM 6/19/2005
SiREJ8
May 4, 2007 04:29 PM
allmotaEM1
Oct 20, 2006 10:37 AM
Ek9ReVciVic
Northern California (Sales)
Aug 13, 2006 03:51 PM
JDM_sedan
Aug 19, 2005 02:56 PM
foonk
Aug 17, 2005 08:11 PM
