Suspension & Brakes Theory, alignment, spring rates....
5 Lug on a D-Series
Old Jun 18, 2005 | 08:53 AM
...Baker's Avatar
Default 5 Lug on a D-Series
Ok, I've searched and read many different how-to's and opinions on the ITR 5-lug converstion only to still have a few questions to ask.
First off, which axles do I need to run? I've been told many different things; to use the USDM ITR axles, that any b-series axles will work and that I should stay away from JDM swaps. Can someone please shed some light on which axles to use?
Secondly, can I use the stock DX brake lines in the front and back? Not necisarily the stock rubber ones but steel braided lines made for 96-00 coupes?
and finally, for swaps that don't come with any e-brake cables.... can I just use stock Civic Si e-cables? Or will I need ITR ones aswell?
The car I'm doing the swap on is a 98 Civic DX Coupe. And any help, links, answers are appreciated. Sorry for all the questions
Old Jun 18, 2005 | 06:45 PM
Garrett's Avatar
Default Re: 5 Lug on a D-Series (DXkid888)
USDM or CTR JDM 5 lugs kit will work on any D serie Engine with OEM honda D serie axles
you could still use the OEM 9.5" disk brake oil lines on the 11" ITR/CTR brakes
but on the rear you have to use the ITR/CTR lines
Old Jun 18, 2005 | 06:55 PM
...Baker's Avatar
Default Re: 5 Lug on a D-Series (Garrett)
thank you very much for replying. I was under the impression that I needed to use b-series axles. What you said makes sense to me
Would it be best to just go ahead and upgrade the rubber lines to steel braided line? I just wonder if the difference would be that noticable.
Thanks again
Old Jun 18, 2005 | 07:15 PM
Garrett's Avatar
Braided lines are a lot better if you plan to use your car for AutoX or lapping
for the street keep it stock
on my SI 90
with stock lines
Old Jun 18, 2005 | 09:16 PM
...Baker's Avatar
looks good, all in all how do you like the set up? is it worth the extra weight?
Weight is the ONLY thing I'm concerned with for my coupe....
thanks again
Modified by DXkid888 at 10:31 PM 6/18/2005
Old Jun 19, 2005 | 04:31 AM
Garrett's Avatar
Default Re: (DXkid888)
Brakes are mores important than wiehgt
il weight maxium 5 lbs more than OEM 9.5." civic brakes
Old Jun 19, 2005 | 06:41 AM
...Baker's Avatar
That's not bad at all. Thank you for the help, much appreciated
Too_slow_eg
Suspension & Brakes
16
May 7, 2009 10:58 PM
Boriqua0555
Jun 28, 2007 10:13 AM
RhdRicheeee
Nov 21, 2005 04:06 PM
KiNG $h!t
Sep 19, 2004 06:36 PM
mini-cRx
Aug 24, 2003 05:06 PM
