search is not workin just looking for a answer real fast
Old Jun 18, 2005 | 08:40 AM
hcivic99's Avatar
Default search is not workin just looking for a answer real fast
i lost the instructions to my air fuel raito guage can some one help. oh and i know that it suxs becuase it is not wideban so dont even bother posting that **** haha thanks
were does the signal wire go ?
Modified by hcivic99 at 1:23 PM 6/18/2005
Old Jun 18, 2005 | 08:41 AM
Luserkid's Avatar
Default Re: search is not workin just looking for a answer real fast (hcivic99)
wat do you want?
Old Jun 18, 2005 | 08:46 AM
hcivic99's Avatar
Default Re: search is not workin just looking for a answer real fast (Luserkid)
how to wire the thing
Old Jun 18, 2005 | 08:52 AM
Relic1's Avatar
red - power
black - ground
some other color - signal
larger wires that connect to a bulb - light
**edit** wire colors in the car.
White - C16 - O2 signal
if you want to run the power and ground to the ECU you can.
A11 or A24 work good for power (yel/blk wires)
ground it to anything metal.
lighting wires are red/blk for positive and red for negative. wires are at the dimmer in the dash.
You can also pull them from the cigarette lighter, power, ground and lights are all ready there. Should be the same colors except the power is yel/grn and ground is blk.
Modified by Relic1 at 12:03 PM 6/18/2005
Modified by Relic1 at 12:06 PM 6/18/2005
Old Jun 18, 2005 | 09:38 AM
hcivic99's Avatar
Default Re: (Relic1)
so what do i conect the signal wire to?
Old Jun 18, 2005 | 09:45 AM
Luserkid's Avatar
Default Re: (hcivic99)
White off the o2 sensor.
Old Jun 18, 2005 | 09:47 AM
hcivic99's Avatar
Default Re: (Luserkid)
how should i go about getting the wire underneath the car to the o2 sencer
Old Jun 18, 2005 | 09:48 AM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hcivic99 &raquo;</TD></TR><TR><TD CLASS="quote">how should i go about getting the wire underneath the car to the o2 sencer
Your shitting me right? How about you jack up the car and crawl under there. Just drop the wire and connect it. Its not brain surgery
tumbaumba
Engine Management and Tuning
Aug 16, 2016 03:34 AM
Racermech
May 23, 2005 08:29 AM
Nusport_racing
Aug 23, 2004 05:35 PM
NathanMorris
Jul 14, 2004 09:45 PM
