Threaded hole in LS block
Old Jun 18, 2005 | 12:20 AM
SPOOLINmatt's Avatar
Default Threaded hole in LS block
i have an ls block i just got done building but before i can run it i have to plug this hole in the back of the block. some people say it was for something on obd0 which the block is from an obd0 car. anyways, does anyone know the thread size for this hole so i can plug it. its to the left of the filter.
http://members.aol.com/arsenic57/holes.jpg
Old Jun 18, 2005 | 10:21 AM
Default Re: Threaded hole in LS block (SPOOLINmatt)
ttt
Old Jun 18, 2005 | 11:06 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
go to a junkyard, look for a 90-91 teg, and yank out the sensor that fills in the hole. i'm pretty sure thats the coolant temp sensor or the fan switch. that sensor is on the thermostat housing on obd1 cars.
as for the hole to the right of the filter, thats for a square black box that ventilates your crankcase. grab one of these from the junkyard as well.
Old Jun 18, 2005 | 04:28 PM
Default Re: (^^whatnoobsearchthenGTFO)
it doesnt go to the water passage on the block. i was thinking it was like a oil temp switch for something or another cause it looks like is an oil area. i cant tell though.
Old Jun 18, 2005 | 05:56 PM
slomofo's Avatar
GDD Member
Default Re: (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">it doesnt go to the water passage on the block. i was thinking it was like a oil temp switch for something or another cause it looks like is an oil area. i cant tell though. </TD></TR></TABLE>
There's a plug in that hole for B18A1's, B17A1's have a sensor in that hole.
Old Jun 19, 2005 | 10:24 AM
Default Re: (slomofo)
what the **** goes there dammit. i could just go buy the sensor at autozone if its cheapo
Old Jun 19, 2005 | 05:15 PM
slomofo's Avatar
GDD Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">what the **** goes there dammit. i could just go buy the sensor at autozone if its cheapo</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">
There's a plug in that hole for B18A1's, B17A1's have a sensor in that hole. </TD></TR></TABLE>
Edit: Plug = Small bolt that PLUGS the hole.
Examples: My oil drain plug blocks oil from draining out of the pan.
My radiator has a plug at the bottom used to drain coolant.
Old Jun 19, 2005 | 08:05 PM
oh my god i know how the sensor goes in there, im not a retard. knock sensor installs the same way. but i cant go to autozone and tell them i have a hole in my block that needs a sensor, what is it?
Old Jun 20, 2005 | 03:23 AM
GOLDBERG's Avatar
are you ****** listening or are you stupid?he said its ****** PLUGGED usually..wake up dummy
Old Jun 20, 2005 | 07:01 AM
Default Re: (GOLDBERG)
i know what it usually is or isnt. i know its eitehr plugged or has a sensor ive always known that but i dont know the thread size. THATS ALL IM ASKING. TAHTS ALL IVE ASKED FROM THE BEGINING.
Old Jun 20, 2005 | 07:03 AM
acy76's Avatar
That threaded plug you've got circled is where the oil temp. sensor is located (I believe only found on 90-93 Integras; there is a plug in its place on later models). This sensor will run the AC fan for 15 minutes after shutdown if the oil is over a certain temperature. It's buried in the electrical section of the Helm manual.
The other hole is for the breather box (black box).
Old Jun 20, 2005 | 09:29 AM
Default Re: (acy76)
yeah i found that sensor today in a guys local **** motor stash. thanks for the info though.
99teggsr
Aug 7, 2013 12:34 PM
dls_tech
Dec 11, 2010 07:36 AM
hybridej7
Jan 8, 2005 02:07 PM
vtecrx
Jun 28, 2004 07:03 AM
Brian_92GSR
Mar 27, 2002 09:17 PM
