SUB NOT WORKING PROPERLY PLZ HELP
my sub is going nuts the beat is not clean, sounds disorted, and the high freq and low frequency bass is all messed up. i tuned the amp according to the jlaudio website. and plus everytime i turn my stereo off i hear a loud *** head-banging bass from the sub, it wont stop till i turn the stereo back on. wtf is goin on? plz help
One thing for sure is you have a wiring problem, need more info, what kind of HU, what JL amp, what sub, in what kind of box, what was used for wiring the amp where in the car was the wire/cable run, are there more amps?
94
94
Your RCA cables are:
A) Bad
B) Grounded out
C) Pinched somewhere
D) has metal contacting 12v
Trace all wiring and make sure none is pinched or grounded out and get some different RCA's (borrow, or see if a local shop will let you use a set in the parking lot) Take out your radio and plug the rca's straight from the radio to the amp theu the middle of the car (nothing fancy) And see if it helps.
Good luck!
A) Bad
B) Grounded out
Good luck!
