What piston specifications...???
I am going to be boosting my car soon and i am going to be replacing the pistons, rods, head gasket,etc...But what pistons(size) do i need that will fit into my engine without any boring,etc(it is a d16y8) I was wanting to get some decent/fairly cheap pistons. What do i need to look at when getting the pistons to make sure they will fit in my stock motor??also,what do i need to get along with the pistons?(ex:rods,rings...)Do i need wrists and pins or can i use stock since i am only wanting around 250-ish hp??if not where can i find some good cheap ones???
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshcivic00 »</TD></TR><TR><TD CLASS="quote">I am going to be boosting my car soon and i am going to be replacing the pistons, rods, head gasket,etc...But what pistons(size) do i need that will fit into my engine without any boring,etc(it is a d16y8) I was wanting to get some decent/fairly cheap pistons. What do i need to look at when getting the pistons to make sure they will fit in my stock motor??also,what do i need to get along with the pistons?(ex:rods,rings...)Do i need wrists and pins or can i use stock since i am only wanting around 250-ish hp??if not where can i find some good cheap ones???
thanks</TD></TR></TABLE>
Piston size? use the same size you currently have in your motor.
If you want to boost your car you want to look at low compression pistons such as 9:1 pistons. Size diameter you want to use the stock size but the compression you want lower in order for the boost to make up for it.
Aftermarket rods are a good idea and rod bolts also to keep the rod on the crank. Wrist pins come with the pistons
CovertFI
Nov 20, 2002 04:01 PM
