new pistons... NEED HONE?
Old Mar 25, 2004 | 08:46 PM
alfee's Avatar
Default new pistons... NEED HONE?
i got some srp pistons pressed onto rods and it doesn't fit properly (almost but way too tight) in my block.. putting new rings and all that good stuff on them, will i need to hone my block so the piston's will fit?
Old Mar 25, 2004 | 08:49 PM
VNTEC's Avatar
B A N N E D
Default Re: new pistons... NEED HONE? (alfee)
The question is.. What size bore were those pistons made for? Stock bore is 81mm. Find out exactly whats the specs of ur new piston... If theyre 81.25 then u need to bore ur motor out.. DO NOT FORCE IT IN... You can do a lot of damage!
Old Mar 25, 2004 | 09:17 PM
ITSTOCK's Avatar
Id recommend you taking it to a machine shop and having them check it over, it will need to be bored if you got oversized pistons.
Old Mar 25, 2004 | 09:23 PM
alfee's Avatar
Default Re: new pistons... NEED HONE? (ITSTOCK)
yeah that's most likely what i'm gonna do.. more $$$ but oh well... turbo don't come cheap! koo!
Old Mar 25, 2004 | 09:32 PM
ITSTOCK's Avatar
Doing things right the first time pays off in the end...
Old Mar 25, 2004 | 09:54 PM
alfee's Avatar
yeap, but after 6 months and close to $5g's on this proj. i've just about run out of patience...
ludeking1007
Apr 8, 2010 09:15 AM
CARMA_626
Dec 2, 2007 03:33 PM
GetawayInMoscow
Jan 5, 2007 06:51 AM
slammedef06
Sep 4, 2005 07:57 PM
ludesleep
May 7, 2003 09:58 PM
