woofers in tha KICK panels? - ECU issues?
Old Jun 17, 2005 | 08:07 PM
CYM19z's Avatar
Default woofers in tha KICK panels? - ECU issues?
Okay.. any issues w/ putting a woofer or anything w/ a powerful magnet in tha kick panels.. - im only worried about my ECU getting messed up .. u know.. please help me out...
Old Jun 18, 2005 | 06:09 AM
CYM19z's Avatar
Default Re: woofers in tha KICK panels? - ECU issues? (CYM19z)
bump --- i was thinking of installin 8" mid-range woofes in my kick panels.. u know glassing them in... but then tha issue of my ECU came into play.. so what do i do???
Old Jun 18, 2005 | 09:28 AM
Nyceguy17's Avatar
You have to put the ECU somewhere else. It won't fit in there with a woofer. Screw it down under you pass side floormat near the firewall and tell passengers to be careful.
Old Jun 18, 2005 | 09:41 AM
EBP_SI's Avatar
Default Re: woofers in tha KICK panels? - ECU issues? (Nyceguy17)
yeah if you leave the ecu in place you'll end up with zero mounting depth and you'll have to end up building it far into the foot space. just move the ECU and you're set.
Old Jun 18, 2005 | 05:50 PM
CYM19z's Avatar
Default Re: woofers in tha KICK panels? - ECU issues? (EBP_SI)
sounds good.t here is a spot behind my glovebox.. like an open area in my dash.. ill stik it there.... thanks for tha info...
eric5984
11
Apr 23, 2019 10:53 PM
_HANS
Jun 13, 2004 03:33 PM
SOHC_MShue
Oct 14, 2002 11:22 AM
95integra_gsr
Dec 18, 2001 03:18 PM
