f22c
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">findign a fwd tranny that works with it would be fun too since it spins the opposite direction as the stock engine.</TD></TR></TABLE>
or just turn the motor around 180 degrees
if you monted the tranny output joint right to a FWD differential, specially made w/ its own housing, you could power both wheels....the the passenger side axle would be 2 inches long, while drivers side would be nearly the entire car wirdth
k series tranny...
k series tranny...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BaGGed HoNDa »</TD></TR><TR><TD CLASS="quote">k series tranny...</TD></TR></TABLE>
bolting to an F22c??...i doubt it...in reality you could probably run any number of FWD honda trannies...you'd just need an adapter.....
for instance, i know one exists to run a d series (d16y7?) to an F block (used for drag racing)
OT: speaking of drag racing, you guys see that Bisi is now running his carbed F22B2 in an insight!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi »</TD></TR><TR><TD CLASS="quote">
OT: speaking of drag racing, you guys see that Bisi is now running his carbed F22B2 in an insight!!</TD></TR></TABLE>
you could do it if you had enough JB weld
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEROPE »</TD></TR><TR><TD CLASS="quote">you could do it if you had enough JB weld
not if the flywheel clutch assembly doesnt fit inside the bell housing, or if the clutch and input shaft dont line up
</TD></TR></TABLE>not if the flywheel clutch assembly doesnt fit inside the bell housing, or if the clutch and input shaft dont line up
Keep in mind too, the F20C and F22C are both built specifically for the S2000, its weight, body type and every aspect of that car alone...you'd get it in an accord (with whatever work it took) and you'd have more weight strain on this engine, which has very little torque. You'd have a motor that was built to actually help balance the S2000 sitting in a position which does nothing (or possibly effects negatively) the accord chassis. Its kind of a BAD idea when you start thinking about different things involved...
And making this formula mate with an FF setup...thats just silly. In the end, you'd have a car that didnt perform all that well...an engine and transmission (and a bunch of one off parts) that you spent a fortune on. Not to mention the almost certain problems you'll run into with various parts not holding up or needing strengthening.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi »</TD></TR><TR><TD CLASS="quote">lest be frank, this is a dumb idea, and would cost uber amounts of time and money....waster</TD></TR></TABLE>
agreed
agreed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnosisracing »</TD></TR><TR><TD CLASS="quote">Keep in mind too, the F20C and F22C are both built specifically for the S2000, its weight, body type and every aspect of that car alone...you'd get it in an accord (with whatever work it took) and you'd have more weight strain on this engine, which has very little torque. You'd have a motor that was built to actually help balance the S2000 sitting in a position which does nothing (or possibly effects negatively) the accord chassis. Its kind of a BAD idea when you start thinking about different things involved...
And making this formula mate with an FF setup...thats just silly. In the end, you'd have a car that didnt perform all that well...an engine and transmission (and a bunch of one off parts) that you spent a fortune on. Not to mention the almost certain problems you'll run into with various parts not holding up or needing strengthening.</TD></TR></TABLE>
not that i dont agree with you 100%, but just FYI, the F20c makes more torque than the F22a, F22b and F23a, all be it probably much higher in the powerband.....
Econo'Box
Aug 10, 2008 08:49 PM
accordlooksick
10
Jun 15, 2004 11:50 PM
