removing the fuel rail on 96 Accord 2.2L VTEC
Old Jun 17, 2005 | 02:42 PM
khkchan's Avatar
Default removing the fuel rail on 96 Accord 2.2L VTEC
I need to remove the fuel rail and fuel injectors to access to the EGR ports under the fuel rail. I am a DIY type people and I am a little bit nervous on doing this. I have a Hayes manual and I believe I understand the procedures: 1: remove the electrical connectors to the fuel injectors; 2: disconnect the fuel pump tube; 3: disconnect the fuel return tube; 4: pull the fuel rail out. Should I do it when the car is cold? How do I relief the fuel pressure?
If you have done this before, do you mind sharing your experience on this? Any special precautious?
Thanks~
Old Jun 17, 2005 | 03:27 PM
95ACM's Avatar
Default Re: removing the fuel rail on 96 Accord 2.2L VTEC (khkchan)
I did that here. I just did not remove the whole thing, just moved it enough out of my way. I would do it with the engine cold.
http://www.dhost.info/accordinfo/howto/egr.html
Old Jun 17, 2005 | 03:34 PM
khkchan's Avatar
Default Re: removing the fuel rail on 96 Accord 2.2L VTEC (95ACM)
Old Jun 22, 2005 | 11:49 AM
khkchan's Avatar
Hi 95ACM,
Did you get a new EGR chamber gasket, fuel injector O-rings and seal rings for this project or did you just use your old ones?
Thanks.
Old Jun 22, 2005 | 04:06 PM
honda_kid42's Avatar
no matter what i would still replace all the gaskets and o-rings....not very expensive from honda and could save alot of time if one is faulty using the old ones!!!
Old Jun 22, 2005 | 06:45 PM
95ACM's Avatar
Default Re: removing the fuel rail on 96 Accord 2.2L VTEC (honda_kid42)
I made sure not to bend anything too drastically and just reused the old ones. They showed no signs of wear, and there are no leaks. If I was going to replace the rings and gasket I wouldn't have done it so lazily, eg: not removing the fuel rail fully
On a side note, I cleaned the EGR because I failed the emissions inspection, took it back a day ago and passed.
CoastalSi
Dec 21, 2010 08:01 PM
The-Kid
Dec 2, 2006 05:14 PM
Adam_F123
Jun 17, 2004 06:07 PM
unFOB4U
14
Sep 10, 2001 06:31 AM
