building up ls/vtec????
Old Jun 16, 2005 | 07:56 PM
fabe85's Avatar
Default building up ls/vtec????
here is my new setup.
i have a 94s block, and iam getting a 2000 sir b16 head.
which will be a better choice for pistons and cam for this setup.
i was thinking type r pistons with some skunk 2 cams, and gears. also what timing belt will fit an ls/vtec.
Old Jun 16, 2005 | 07:58 PM
Racermech's Avatar
Default Re: building up ls/vtec???? (fabe85)
search button id your friend, all of this has been covered a thousand times.
While you are searching for the timing belt make sure you check which head gasket to use
Old Jun 16, 2005 | 09:00 PM
Spectrum24x's Avatar
Default Re: building up ls/vtec???? (Racermech)
instead of type r heads, i'd go for aftermarket, your gonna pay about the same amount, and u can get a lot more power ouf ot some JE High compression pistons. don't forget aftermarket rods and bearings, I'd get a block girdle too.
and springs and retainers for the head...
unless u only need the motor for a few months.
Old Jun 16, 2005 | 09:02 PM
Kendall's Avatar
Default Re: building up ls/vtec???? (Spectrum24x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x &raquo;</TD></TR><TR><TD CLASS="quote">instead of type r heads</TD></TR></TABLE>
Where in the original post is a Type R head mentioned? Also note that Honda 4 bangers use only one "head."
Old Jun 16, 2005 | 09:12 PM
Default Re: building up ls/vtec???? (Kendall)
sorry, i meant pistons, its late.
Old Jun 16, 2005 | 09:17 PM
sorry, i mean pistons... its late.
Jdm John
Sep 23, 2009 09:34 AM
93slmdcvcsi
Aug 22, 2005 08:23 PM
Grand
Mar 28, 2005 02:00 PM
blueskiesfade609
Feb 16, 2004 06:11 AM
