speed sensor
Old Jun 16, 2005 | 07:18 PM
jdmcoupe28's Avatar
Default speed sensor
i've been having a problem with my spedo. i changed the VSS and it still doesn't work. it keeps throwing a code 17 which is VSS.. its a b18b with a gsr trans the spedo use to work then it just stoped.. ne ideas? i checked the gauge cluster and its not the problem. let me know a.s.a.p i/m s/n is iluvmyjdmhona. thanks
Old Jun 16, 2005 | 08:54 PM
337 GTI 1.8t's Avatar
Default Re: speed sensor (jdmcoupe28)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcoupe28 &raquo;</TD></TR><TR><TD CLASS="quote">i've been having a problem with my spedo. i changed the VSS and it still doesn't work. it keeps throwing a code 17 which is VSS.. its a b18b with a gsr trans the spedo use to work then it just stoped.. ne ideas? i checked the gauge cluster and its not the problem. let me know a.s.a.p i/m s/n is iluvmyjdmhona. thanks</TD></TR></TABLE>
check for continuity to make sure the wires are all a-ok coming from the VSS to their various positions within the car.
Old Jun 17, 2005 | 05:49 PM
PrettyLude's Avatar
check the wiring of the vss, and make sure no moisture is in the plug that goes into the vss
civicSF98
10
Aug 30, 2009 05:10 PM
crick_james
Transmission & Drivetrain
10
Mar 5, 2009 11:27 AM
gorillapno
May 26, 2008 09:38 PM
Jackadeal
Mar 10, 2006 03:18 PM
DumpedSi
19
Sep 11, 2003 04:10 PM
