Car running idle RPM needle keeps going up and down slightly
Old Jun 16, 2005 | 06:50 PM
jch444's Avatar
Default Car running idle RPM needle keeps going up and down slightly
Have integra ls 1995 160,000 miles. Car is completely stock.
Have recently noticed that the when the car is idle the RPM needle keeps moving up and down slightly. When I hit the gas (car is at standstill and in neutral) the RPM needle accelerates to the level I let it accelerate too...but then when I let the gas go the needle drops so low the car almost wants to turn off. Then goes back to normal idle which is slightly below 1000 RPM's. Performed a tune up about 2 months ago and still the same issues. Please help....Any ideas would be greatly appreciated.
Old Jun 16, 2005 | 07:10 PM
adseguy's Avatar
Default Re: Car running idle RPM needle keeps going up and down slightly (jch444)
sounds exactly like a vaccum leak. check/replace all your vaccum lines
Old Jun 17, 2005 | 06:45 PM
jch444's Avatar
Default Re: Car running idle RPM needle keeps going up and down slightly (adseguy)
thanks...will try and let you know...
Old Jun 17, 2005 | 07:51 PM
DA6Iceman's Avatar
sounds like your eacv located on the back side of the intake manifold, my crx did that and thats what it was
Old Jun 17, 2005 | 08:07 PM
jch444's Avatar
Default Re: (DA6Iceman)
thanks for the input. Will try to pull from my cousin's 95 LS and swap... These types of issues are a pain to troubleshoot. What's the best way to check for a vacuum leak...?
jwest1150
14
Apr 20, 2011 12:17 PM
pbizzlegsr
Mar 13, 2004 01:04 AM
preluder
Jul 25, 2003 11:57 AM
ahc'monracing
Oct 22, 2002 07:38 PM
