Pic Request..dizzy wires/wire harness for sohc 92-95 civics..
i cant figure out which wires goes to which...(from the wire harness to the dizzy harness) its a project car, so the wires arent in the right places on the wire harness. just wandering if anyone has a pix or a correct diagram of which goes to which. its just oem 92-95 wire harness to 92-95 dizzy harness.
also would like to know the firing order as well. and yes its diff than b-series
correct me if im wrong..firing order
1 3
2 4
4 3 2 1
according to this pix...
1 3
2 4
4 3 2 1
could someone go look on their sohc and see which colors goes to which from the wire harness to the dizzy. obd1 please
From: Why so you can pretend like youre interested, FL/OK
Line 1: black/yellow - blue/black - yellow/dark green
Line 2: white - light yellow/light green - white/light green
Line 3: beige - light green/yellow - light green
Line 1 starts at the very top (closest line to the firewall) going from left to right, facing side as if it were installed into the camshaft. Therefore, line 3 is closest to the radiator.
Now, for the two plug connector:
blue/black - black/yellow, clip side up
For the 7 pin connector (clip side up):
Line 1: white - light yellow/light green - light green - yellow/dark green
Line 2: beige - white/light green - light green/yellow
OBDI VTEC Distrib.
OBDI VTEC Distrib.
starbai
Apr 3, 2009 12:45 PM
truevietluv636
19
Mar 28, 2007 03:40 PM
HoNdAeX11
Jul 21, 2003 02:53 PM
