Help please... valve clearance for b18c?
Old Jun 16, 2005 | 05:10 PM
lopaka07's Avatar
Default Help please... valve clearance for b18c?
Hey all.... Gonna adjust my valves but I've got a b18c in an eg. I'm assuming the valve clearance for the intake and exhaust are different for the b18c than the original sohc. Can anybody help me out and tell me what the clearance should be for the intake and exhaust? Thanks for the help.... really appreciate it....
Old Jun 16, 2005 | 05:38 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Help please... valve clearance for b18c? (lopaka07)
Are you literally adjusting the valve guide to stem clearance? Or just adjusting the rockers against the cam lobes?
Well....I'm bored. Here are the specs for both:
With a dial indicator while rocking the stem in the direction of normal thrust (wobble method):
Intake Valve Stem-to-Guide Clearance:
Standard (New): 0.05 - 11 mm (0.002 - 0.004 in)
Service Limit: 0.16 mm (0.006 in)
Exhaust Valve Stem-to-Guide Clearance:
Standard (New): 0.10 - 0.16 mm (0.004 - 0.006 in)
Service Limit: 0.22 mm (0.009 in)
There is another method to measuring this by subtracting the outer diameter of the valve stem from the inner diameter of the valve guide with a micrometer. If you need these numbers instead, lemme know and I'll give them to you.
As for regular valve adjustments....
I assume you know the order and the method (i.e.: sequence and adjusting them cold, etc):
Intake: 0.15 - 0.19 mm (0.006 - 0.007 in)
Exhaust: 0.17 - 0.21 mm (0.007 - 0.008 in)
Old Jun 16, 2005 | 05:48 PM
lopaka07's Avatar
Thank you very much. Great info, but more than I was looking for. I'm just wondering what the regular valve adjustment clearance was because it's not the stock motor in the car. Sorry I didn't mention that. But thanks again.....
Old Jun 16, 2005 | 05:56 PM
shamoo's Avatar
Default Re: (lopaka07)
No problem. Lemme know if you need more info. I have a Helms service manual here.
STATek9
Sep 18, 2009 08:47 AM
redDAinteg
Dec 8, 2007 02:44 AM
street rat
Nov 15, 2007 03:26 PM
b18sihatch
May 10, 2007 07:46 PM
AllMoToRB18c
Jul 23, 2003 10:03 AM
