looking for Stock O2 sensor accuracy
Old Feb 11, 2002 | 02:29 PM
Renegade's Avatar
Default looking for Stock O2 sensor accuracy
I am looking for the stock O2 sensor accuracy, or at least a comparison with a wideband sensor...
Old Feb 11, 2002 | 02:31 PM
sgT's Avatar
sgT
Default Re: looking for Stock O2 sensor accuracy (98401R)
cant compare to a wide band
Old Feb 11, 2002 | 02:36 PM
Renegade's Avatar
Default Re: looking for Stock O2 sensor accuracy (sgT)
looking for actual numbers
Old Feb 11, 2002 | 02:49 PM
sgT's Avatar
sgT
narrow band 0-1V
wide band 0-5V
Old Feb 11, 2002 | 03:14 PM
Renegade's Avatar
should have been more specific. I am looking for accuracy, I know what the accuracy of the wideband is but not for the stock O2 sensor.
Old Feb 11, 2002 | 03:28 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
sure you can compare them, not on a 1 to 1 ratio, but close enough to notice any discrepancies. It is obvious that you will get more accurate data on a sensor that operates on a wider voltage range, but it doesn't mean that you can't "mathematically" compare their readings.
I have a 30 LED Halmeter, which breaks the voltage (0 to 1.1 volt) into 30 data points, and if my memory serves me right, at the dyno, it was actually close to the wide band. My TWM halmeter, gives 10 leds for lean, 10 for stoich and 10 for rich mixture conditions. It goes from 14:1 to 12.5:1 I tuned my car by setting the WOT mixture at the fourth rich LED which corresponds to ~13.5. At the dyno, we only improved by 2 HP while tuning the air/fuel with the wide band.
I would like to add that these results were on brand new Bosh Lambda O2 sensors.
That was my experience, it might not be the same for you.
[Modified by Spaceballs the lunch box, 12:29 AM 2/12/2002]
RTW DC2R
Jul 16, 2003 05:42 AM
NeXtLeVeL_TyPe_R
Mar 19, 2002 03:54 AM
Westrock2000
Feb 25, 2002 05:20 PM
89turboteg
Feb 11, 2002 07:19 PM
fastestdriver
Jan 19, 2002 08:04 PM
