GSR tranny on a DA?
Old Jun 16, 2005 | 03:36 PM
LoseRPunKx182's Avatar
Default GSR tranny on a DA?
it should work but i'm just making sure...a DC GSR tranny on a b18 DA would work right?
Old Jun 16, 2005 | 03:41 PM
BlackDAy's Avatar
Default Re: GSR tranny on a DA? (LoseRPunKx182)
yes. as long as you switch the tranny out with the corresponding tranny...ex: cable, hydraulic.
Old Jun 16, 2005 | 04:16 PM
projectTeG's Avatar
yes and no ...itll bolt to the engine fine, but it won't bolt into the car, because the transmission mount is different , you can get lucky and get the place racing cable to hydro mount from someone used since place racing went out of buisness or wait for hasport to release the mount...or you could prolly modify the mount in the engine bay. to get the hydrolic clutch to work in the cable chassis you could plumb the hydrolic lines from a dc into the da or you could get the kit from hasport that enables you to use the cable system on the hydro tranny.depending on the type of cable tranny you might or might not have to change the clutch....90-91 tranny, you have to change the clutch because the clutch spline inb the tranny is smaller. 92-93 no because the clutches are the same. serch around more and youll find out more on the subject....in the honda world the gen2 tegs are kinda black sheeped, but its changing now...slowly, but atleast were getting more options
Old Jun 16, 2005 | 04:54 PM
MR-MUGEN's Avatar
Default Re: (projectTeG)
^^in other works if you got the money yes , if you don't no
Old Jun 16, 2005 | 05:03 PM
UNKNOWN_MEMBER's Avatar
What? i never knew that, i thought it would bolt up. My friend uses a itr hydro tranny in his DA with no problems and i use a b16cable tranny. Don't they all have the same location of the mounts? If they were different then how come when you swap b series in hatchbacks they only have 1set of mounts for all b series? hm.....thats wierd.
Old Jun 16, 2005 | 05:31 PM
projectTeG's Avatar
Default Re: (UNKNOWN_MEMBER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">What? i never knew that, i thought it would bolt up. My friend uses a itr hydro tranny in his DA with no problems and i use a b16cable tranny. Don't they all have the same location of the mounts? If they were different then how come when you swap b series in hatchbacks they only have 1set of mounts for all b series? hm.....thats wierd.</TD></TR></TABLE>
the front transmission mount is located on the cross-member, but on the newer eg, dc they dont have a cross member so the torque mounts are located on the lower parts of the front bulk-head. the newer cars have 5 mounts, da's have 4.
your buddy might have the conversion mount or modded the engine bay.
Old Jun 16, 2005 | 06:16 PM
Can't you just run 3 mounts? driver side, back of motor, and tranny(passenger)?
Old Jun 17, 2005 | 02:09 AM
up for more answers?
i got a 92 DA btw
Old Jun 17, 2005 | 02:28 AM
DA6Iceman's Avatar
Default Re: (LoseRPunKx182)
we ran 3 mounts on my buddies c1 and it worked ok but he only had the car for 2 months after that so we really didnt see what the long run was, but on my friends b16 we ran 3 and it was fine with urethane bushings
Old Jun 17, 2005 | 08:58 AM
any truth to the first part?
Old Jun 17, 2005 | 02:15 PM
Old Jun 17, 2005 | 08:10 PM
is the first one what i'm looking for?
http://www.nipponpower.com/eng....html
Old Jun 19, 2005 | 01:15 PM
that just deals with the hydro to cable conversion. no mounts on that one.
viking-101
Jun 26, 2011 07:11 AM
95 vtec
Nov 14, 2006 08:35 PM
vtec25
17
Oct 3, 2006 06:57 PM
clemsonteg
Dec 27, 2005 07:32 PM
HamiltonRex
Dec 23, 2004 04:33 PM
