ITR w/nitrous - timing issue
Old Feb 11, 2002 | 02:03 PM
TypeR1558's Avatar
New User
Default ITR w/nitrous - timing issue
The installer just told me that he has the timing on my ignition kicked back to 6 degrees just to be safe. What kind of a power increase will I see if I only retard 4 degrees? Is it a big jump in power? He said it is also running rich, just incase I happen to get bad gas one time I fill up. Does this stuff sound right? I dont want to be missing out on a lot of power.. what should I do?
Thanks,
Jon
Old Feb 11, 2002 | 02:29 PM
sgT's Avatar
sgT
Default Re: ITR w/nitrous - timing issue (TypeR1558)
with that much nitrous i would run 6 retard anyway, just to be safe.
when you said you are running rich, i hope thats not all the time.
you can rejet the fuel so it is more than necessary so you are only rich
while spraying.
Old Feb 11, 2002 | 02:51 PM
TypeR1558's Avatar
New User
Default Re: ITR w/nitrous - timing issue (sgT)
I am only running rich while spraying I think... how do i make sure that he set it up so I am only running rich while spraying and not when off the bottle. I am assuming that you are saying the best method is for him to just spray more fuel through the fuel jets when spraying, and not adding more fuel with the stock fuel system... right? How much whp/tq should I be making with an 80 shot if I am tuned properly?
Thanks as always Steve..
Jon
Old Feb 11, 2002 | 04:06 PM
Pinhead's Avatar
New User
Dude 6 degrees is a lot of timing retard...6 is not needed for only an 80 shot trust me....I have my timing at 18 degrees but when my NOS kicks in it drops to 13 degrees...and everything seems to be running smoothly and it's been like that since October basically
gtistile
Jul 21, 2005 11:51 AM
Mantis88ls
May 14, 2004 05:37 AM
1990s10
May 27, 2003 06:32 PM
ratherbewalking
Dec 30, 2002 08:20 AM
lsteggy
Dec 17, 2002 04:01 AM
