Anyone had this problem? (searched)
Old Jun 16, 2005 | 12:40 PM
stringcheese840's Avatar
Default Anyone had this problem? (searched)
Today on my way to work it started to rain so i put my windows up and turned on the A/C. I guess it was a few minutes later i noticed that the digital clock started to blink just the clock. (I have a 94 prelude VTEC). The clock must have blinked about 6 or 7 times when i noticed that the speedo and tach started going nutz. This happened for about 5sec and then everything was normal for the rest of the ride to work. If anyone knows what may have caused this please help. There are no CEL present. Just a reminder it was only the digital clock and the speedo and tach.
Thanks for any info.
Old Jun 16, 2005 | 04:53 PM
Default Re: Anyone had this problem? (stringcheese840)
i'm guessing that noone has had this same problem before?
Old Jun 16, 2005 | 05:16 PM
JTCdudeman's Avatar
Master H Technician
yes... so, i would guess your wrong. Ive heard it covered several times before. GL , your impatience may hurt you.
Old Jun 18, 2005 | 08:02 AM
now my dash lights will not turn on unless i fiddle with the key in the ignition. Also the car will not start now it acts like it want to turn over but just dies after a second. Please help.
Thanks
Old Jun 18, 2005 | 08:47 AM
01 LudeDude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stringcheese840 &raquo;</TD></TR><TR><TD CLASS="quote">now my dash lights will not turn on unless i fiddle with the key in the ignition.</TD></TR></TABLE>
Did the 4th Gen ludes suffer from the faulty ignition switches like some 5th Gens(5th gen was recalled)?
Old Jun 18, 2005 | 09:46 AM
94svtec's Avatar
Default Re: Anyone had this problem? (01 LudeDude)
Yes I changed mine once .. so far.. has ran great ever since..
Old Jun 18, 2005 | 12:21 PM
AndyD's Avatar
Do you have a lot of keys on your keychain?? I've heard of having too many keys (weight) causing the ignition to go bad.
Are you sure your alternator is working properly?
Old Jun 19, 2005 | 11:27 AM
Default Re: Anyone had this problem? (AndyD)
I think it is the electical part of the ignition switch going to order the part Monday.
KyleVA
Jun 24, 2011 03:55 PM
Don Jefe
Oct 27, 2008 09:37 AM
AnAccordIsForever
Mar 19, 2007 12:45 PM
ChristRocket
Sep 10, 2004 01:56 PM
silver_nteg
Nov 27, 2003 07:00 PM
