Possible to Replace A/C Thermostat without Removing Evaporator?
Old Jun 16, 2005 | 11:10 AM
jlamaster's Avatar
Default Possible to Replace A/C Thermostat without Removing Evaporator?
Like the topic says. Is it possible? I 've looked in the helms and it says to pull the Evaporator but i just wanted to know if any one has replaced it with out.
Old Jun 16, 2005 | 02:02 PM
kkim's Avatar
Default Re: Replace A/C Thermostat without Removing Evaporator (jlamaster)
good question... I'd like to know too, as I'm about to pull the evaporator this weekend to fix what I think is a faulty thermostat.
Old Jun 16, 2005 | 02:33 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlamaster &raquo;</TD></TR><TR><TD CLASS="quote">Like the topic says. Is it possible? </TD></TR></TABLE>
I wouldn't try it.
Old Jun 16, 2005 | 04:42 PM
jlamaster's Avatar
Default Re: Replace A/C Thermostat without Removing Evaporator (Chiovnidca)
why wouldn't you try it? It is eather possible or not. If it is possible you won't have to have your A/C system evacuated so you can pull the evaporator.
Old Jun 16, 2005 | 05:41 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlamaster &raquo;</TD></TR><TR><TD CLASS="quote">why wouldn't you try it? </TD></TR></TABLE>
Because I dont think it would be worth the hassle just to save a little time on evac and charge. If it's possible it would be extremely difficult.
Old Jun 18, 2005 | 07:37 AM
jlamaster's Avatar
after looking at it myself you are right it would be next to impossible. I Found and place that will evac and recharge for $65.00
Old Jun 18, 2005 | 09:35 AM
kkim's Avatar
why do you think you need to replace the a/c thermostat? what is it doing or not doing?
Old Jun 19, 2005 | 03:35 PM
jlamaster's Avatar
Default Re: Replace A/C Thermostat without Removing Evaporator (kkim)
well at frist the a/c system would come on for 10 sec. or so every 10 min. now it won't come on at all. The compressor clutch won't engage nor will the condensor fan come on. I went thru the troubleshooting flowchart in my hemls and when it cames to testing the A/C thermostat it failed. every other component checks out. Im pretty sure this is what is causing the system not to come on. I've checked all the other compenetes independently and they work.
Old Jun 19, 2005 | 04:11 PM
kkim's Avatar
when's the last time you checked the refrigerant pressure? there is a low pressure switch and, I believe, a high pressure switch which prevents the a/c from coming on when the pressure is not w/in acceptable limits.
I ask, cause my a/c was not cycling off and on, but would just stay engaged all the time the a/c button was selected. Like I said eariler, I was planning to pull my evaporator this weekend to change my thermostat, but my a/c started to cycle after my trip to the store for supplies I needed to service the a/c system. guess it knew I was about to tear it apart so it decided to start working on it's own.
just curious, but how did you test the thermostat with it still in place? the test I see in the helms calls for you to remove it to test.
good luck.. please post a follow up once you fix your problem.
Old Jun 19, 2005 | 08:47 PM
jlamaster's Avatar
yeah my pressure is good. I had to jump the compressor clutch to get it to engage but once it did my pressure was normal otherwise if you check your pressure without the system running it will alway read too high. And by testing it i mean in the flowchart it tells you to ground Pin 2 on the A/C thermostat with the A/C button on and it should kick on if the A/C thermostat is good, mine did not. Im going to get one from Honda and jsut plug it into the harness but not have it installed. If the system comes on then i know it is the thermostat. If it doesn't im not sure what could be wrong.
Old Jun 19, 2005 | 09:28 PM
kkim's Avatar
they run about $20 from Honda. Hope that solves your problem. Post your findings after you get the new part.
Good luck...
Old Jun 20, 2005 | 02:58 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlamaster &raquo;</TD></TR><TR><TD CLASS="quote"> Im going to get one from Honda and jsut plug it into the harness but not have it installed. If the system comes on then i know it is the thermostat. If it doesn't im not sure what could be wrong. </TD></TR></TABLE>
You can just jump the t-stat connector with a paper clip and see if the compressor kicks on.
Old Jun 20, 2005 | 06:26 AM
jlamaster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
You can just jump the t-stat connector with a paper clip and see if the compressor kicks on.</TD></TR></TABLE>
I thought about that but i can't figure out which way to jump it. Its a 3 pin connector and there is voltage on pins 1 and 3. So do i put a jumper from pin 1 to pin 2 and a second jumper from pin 3 to pin 2? That is the only way i can see. Which now that i am typing this it makes sense. Im going to go try it right now.
Old Jun 20, 2005 | 02:23 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlamaster &raquo;</TD></TR><TR><TD CLASS="quote">I thought about that but i can't figure out which way to jump it. Its a 3 pin connector and there is voltage on pins 1 and 3. So do i put a jumper from pin 1 to pin 2 and a second jumper from pin 3 to pin 2? That is the only way i can see. Which now that i am typing this it makes sense. Im going to go try it right now. </TD></TR></TABLE>
If I remember right it's only pins 1 and 2 that need to be jumped. Dont jump pin 3 (blk/yel wire) to pin 2 or you'll pop a fuse.
Old Dec 27, 2015 | 06:19 PM
GordieH's Avatar
Icon4 Re: Possible to Replace A/C Thermostat without Removing Evaporator?
just wondering where the a/c thermostat is.
i can't seem to get any answer to that anywhere.
Type X
Honda Civic (2006 - 2015)
16
Jan 11, 2007 03:59 PM
spoonhatchblack
17
Jul 18, 2006 06:44 PM
Ag-Eng
Honda Motorcycles
13
Feb 22, 2005 08:41 AM
stizzit
Welding / Fabrication
12
Oct 21, 2004 03:28 PM
Brent L
Oct 9, 2004 07:12 AM
