BIG PROBLEM NEED HELP
Old Jun 16, 2005 | 09:58 AM
GdmLaz's Avatar
Default BIG PROBLEM NEED HELP
K here is the story the car was on idling fine and all of a sudden it just came 2 a brutal stop and stalled out by itself when u try to crank it it does nothing whatsoever just click, click, lol any1 have any idea what this could be
Old Jun 16, 2005 | 10:27 AM
IHateJDM's Avatar
Default Re: BIG PROBLEM NEED HELP (Slammed92hbonN20)
distributor sieze? bad alternator + dead battery? Threw a rod? Need more info than that.
Old Jun 16, 2005 | 10:31 AM
GdmLaz's Avatar
if the distributor was bad the car would still crank and if the battery was dead my lights will be dimmed or something
Old Jun 16, 2005 | 10:38 AM
IHateJDM's Avatar
Default Re: (Slammed92hbonN20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed92hbonN20 &raquo;</TD></TR><TR><TD CLASS="quote">if the distributor was bad the car would still crank and if the battery was dead my lights will be dimmed or something </TD></TR></TABLE>
i was saying you didn't describe the problem well enough to give a good answer. the battery can have power and not enough to turn the starter.
Old Jun 16, 2005 | 10:43 AM
sohcvtec1995's Avatar
ignition coil?
Old Jun 16, 2005 | 08:10 PM
GdmLaz's Avatar
the motor will still crank the motor doesn't crank at all
Old Jun 16, 2005 | 09:24 PM
GdmLaz's Avatar
up top
Old Jun 17, 2005 | 07:21 AM
cruizinmax's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed92hbonN20 &raquo;</TD></TR><TR><TD CLASS="quote">the motor will still crank the motor doesn't crank at all </TD></TR></TABLE>
You just contradicted yourself. The motor cranks but won't start or the motor dosen't crank at all????
Old Jun 17, 2005 | 07:23 AM
grafffeener's Avatar
is the ignition switch bad? there is a recall that requires us at honda to replace the ignition switch because cars were stalling.
Old Jun 18, 2005 | 12:39 AM
GdmLaz's Avatar
nah i sayd the motor will still crank if the distributor is bad but the car doesn't crank at all
Old Jun 21, 2005 | 02:07 PM
GdmLaz's Avatar
Up ToPpPp
Old Jun 21, 2005 | 02:22 PM
eXcelonTypeR's Avatar
Yeah it will still crank if the starter is still good and the dizzy is bad, it will jsut turn and turn but wont start cause there is no spark. Does it sound like the starter is turning the motor over? If it is then battery and starter are still good and it would have to do with the dizzy, fuel system or maybe a blown fuse probably in the engine fuse box. Can you hear the fuel pump prime if you turn it to the second ON position??
Old Jun 21, 2005 | 03:09 PM
KtHaNxBai's Avatar
Default Re: (eXcelonTypeR)
u just got owned by ur car.
lol
03ep3sicivic
Jun 28, 2009 08:05 AM
Inextricabledrvr
Dec 16, 2008 09:45 PM
aznboi_2
Dec 23, 2006 03:06 PM
icefire069
Jul 4, 2004 08:54 AM
thad
Feb 20, 2004 09:43 PM
