Question about resistor box and high impedance injectors?
Old Jun 16, 2005 | 09:28 AM
MysteryWagon's Avatar
Default Question about resistor box and high impedance injectors?
I still had my resistor box hooked up until I realized it was not needed for my injectors. Three of my plugs show that those cylinders were running lean. Did having the resistor box hooked up cause this? Does the mix of the 2 cause the injectors to not open all the way?
thanks alot
Justin
Old Jun 16, 2005 | 09:38 AM
337 GTI 1.8t's Avatar
Default Re: Question about resistor box and high impedance injectors? (MysteryWagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MysteryWagon &raquo;</TD></TR><TR><TD CLASS="quote">I still had my resistor box hooked up until I realized it was not needed for my injectors. Three of my plugs show that those cylinders were running lean. Did having the resistor box hooked up cause this? Does the mix of the 2 cause the injectors to not open all the way?
thanks alot
Justin</TD></TR></TABLE>
yeah, the resistor box was limiting the current pulse of the drivers; the saturated injectors need the full current pulse to work properly....
anyone concur?
Old Jun 16, 2005 | 01:22 PM
theinfamouskonrad's Avatar
Default Re: Question about resistor box and high impedance injectors? (337 GTI 1.8t)
take out the resistor box for sat. injectors. Just cut the clip that connects to the resistor box off, and solder all those wires together...and your done!
Old Jun 17, 2005 | 04:16 AM
EE_Chris's Avatar
Having the resistor box in there probably kept the injector from opening...or opening very slowly.
Take it out.
ej1serge
Mar 14, 2012 11:33 PM
boosted96teg
Mar 15, 2008 06:35 AM
deucedeuceEK
Oct 30, 2007 04:35 PM
B18 CYA
Jun 24, 2004 06:44 PM
