Recent B16 swap..idleing problem??
Old Jun 15, 2005 | 09:22 PM
TheIceMan's Avatar
Default Recent B16 swap..idleing problem??
Juss like it says....i just swapped my EK with a jdm b16....the engine runs fine but when the car is at a stop it idles up and down....i dun have a tach yet but i would say it flucuates between 1K AND 2k up and down....other than that, no problems yet .
Old Jun 15, 2005 | 10:26 PM
DSRxMilogen's Avatar
Default Re: Recent B16 swap..idleing problem?? (SigleyEK)
CELS? no then it might be a vacuum leak.. what you do is use a spray bottle with soapy water and while the engine is on.. spray along the vacuum lines.. if you see bubbles then you have a leak.. ..
if you do have a CEL.. it depends on what it is.. IAT, IACV etc.. most common one is the IACV tho.. you can always take it out and clean it..
GOOD LUCK
Old Jun 17, 2005 | 11:05 AM
EKrckstarr's Avatar
iac valve
Old Jun 17, 2005 | 12:21 PM
Hatchamaback's Avatar
IACV couldnt make it your idle BOUNCE, the IACv contraols your idle not a abnormal issue like rev bounce. Its either a vaccuum leak 75% of the time, I had a similar problem but my problem was a coolant line running to the Throttle body/Intake manifold, that radiator stop leak clogged the cold start diaphram thinger and it would never open. I just opened it scraped it out and it works like a champ. Hope fully this helps you.
Old Jun 17, 2005 | 02:57 PM
B00M3R's Avatar
Default Re: (conFusedEG)
Could be low on coolant. make sure there is no air in the radiator.
Old Jun 17, 2005 | 03:08 PM
NAiL05's Avatar
Default Re: (B00M3R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00M3R &raquo;</TD></TR><TR><TD CLASS="quote">Could be low on coolant. make sure there is no air in the radiator.</TD></TR></TABLE>
veearr6
Mar 12, 2010 01:12 PM
aakeobo
Jun 7, 2006 07:58 AM
hybridbmw
May 8, 2005 01:58 PM
