GSR ECU AND BUTTERFLY QUESTION
Old Jun 15, 2005 | 08:14 PM
thewonderer's Avatar
Default 96 ek w/GSR ECU AND BUTTERFLY QUESTION p28 ks and iab
96 ek with a gsr|||| Guys a friend of mine has a iab control problem. Its not opening all 8 just 4. can he remove the butterflys to get all sufficient amounts of air or will he lose power.
Also will a p28 ecu read his knock sensor on his gsr or do p28s not look for them and allow him to bypass putting it on.
thanks in advance
Old Jun 15, 2005 | 09:25 PM
ballplayer's Avatar
Default Re: 96 ek w/GSR ECU AND BUTTERFLY QUESTION p28 ks and iab (thewonderer)
i believe if you remove butterflies, you may lose some low end power. Not sure tho...And if you get a chipped p28, you can pretty much chip it how ever you want it....
Old Jun 16, 2005 | 12:39 PM
Default Re: 96 ek w/GSR ECU AND BUTTERFLY QUESTION p28 ks and iab (ballplayer)
yeah can anyone confirm?
Old Jun 16, 2005 | 01:27 PM
ballplayer's Avatar
try a search, i know its been covered many times
Old Jun 16, 2005 | 01:39 PM
IHateJDM's Avatar
removing butterflies does kill some low end power when you floor it since they open at WOT instead of a certain rpm. It does not affect top end. The p28 does not look for knock sensor.
Jmunk
Feb 23, 2005 04:54 AM
tegasaurus
Jun 6, 2004 04:01 PM
thehondaguru
Nov 26, 2003 06:55 AM
djtony5
Feb 27, 2003 08:49 AM
