cam install, what else should i pick up to do it right...
Old Jun 15, 2005 | 02:30 PM
BoostinEJ1's Avatar
Default cam install, what else should i pick up to do it right...
im actually installing a camshaft, valve springs, and retainer into my sohc d16z6 and i just wanted to know if i should pick up anything from honda like some kind of lube or so. im going to get a new valve cover gasket since mine now leaks and a friend suggested a thinner headgasket(i think a y8 is thinner, can some confirm?) and arp studs while the motor is apart. any other useful info would be great. thanks
Old Jun 15, 2005 | 02:58 PM
unknown0001's Avatar
Default Re: cam install, what else should i pick up to do it right... (slowsinglecam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowsinglecam &raquo;</TD></TR><TR><TD CLASS="quote">im actually installing a camshaft, valve springs, and retainer into my sohc d16z6 and i just wanted to know if i should pick up anything from honda like some kind of lube or so. im going to get a new valve cover gasket since mine now leaks and a friend suggested a thinner headgasket(i think a y8 is thinner, can some confirm?) and arp studs while the motor is apart. any other useful info would be great. thanks </TD></TR></TABLE>
Get engine assembly lube and lube up all the lobes on the camshaft and the valve portion that will be close to the camshaft rather then the block.
If you want to get a bit higher compression getting a thinner head gasket might raise you by .1 - .3 depending on how thin. APR head studs are a good choice also
Old Jun 15, 2005 | 03:16 PM
BoostinEJ1's Avatar
thanks a lot man
Old Jun 15, 2005 | 03:38 PM
skunked's Avatar
Default Re: (slowsinglecam)
replace the cam seal too.
Old Jun 15, 2005 | 05:30 PM
mmuller's Avatar
Mad Scientist
Default Re: (skunked)
valve seals and KY gelly for those moments
Old Jun 16, 2005 | 09:33 PM
skunk2finatic's Avatar
If your doin all that crap, go and get a head gasket kit. It'll have all the gaskets and seals from the head gasket up...you'll need 98% of them, trust me.
Old Jun 16, 2005 | 11:32 PM
EnzoSpeed's Avatar
Default Re: cam install, what else should i pick up to do it right... (skunk2finatic)
First off, you should know that there is a simple answer to the question many people seem confused about.
All z6 head gaskets are 3 layer. The y8 engine was originally manufactured with a 2 layer head gasket, but in later years switched back to the standard 3 layer. So many people argue over which gasket creates higher compression. You will find, though, that most replacement y8 and z6 head gaskets are identical and made in 3 layers.
Some people just blindly spout out that the y8 gasket is better because some of them are only 2 layers thick.
Old Jun 17, 2005 | 05:45 PM
_BEN_'s Avatar
Make sure you have all of the tools needed.
Torque wrenches
Valve tool
Helms manual
Sometimes a friend that knows what they are doing helps.
Old Jun 17, 2005 | 05:53 PM
EnzoSpeed's Avatar
Default Re: cam install, what else should i pick up to do it right... (_BEN_)
I've done everything with just a haynes.
Old Jun 17, 2005 | 06:09 PM
_BEN_'s Avatar
Default Re: cam install, what else should i pick up to do it right... (EnzoSpeed)
Helms and Haynes are both adequite but why not use the better of the two. Especially when it is coughfreecough.
Old Jun 17, 2005 | 11:16 PM
methos713's Avatar
lol...search and you will find...coughFREEcough...or you can ask
viscious2stroke
Mar 6, 2014 05:44 AM
1991civicsi
Mar 24, 2006 08:03 PM
Shizznaz
Feb 6, 2005 02:44 PM
PearlWhiteAccord
Jan 8, 2004 01:13 PM
max
Oct 19, 2001 07:28 PM
