Adheasive better than JBWeld
Old Jun 15, 2005 | 12:34 PM
Paprika's Avatar
Default Adheasive better than JBWeld
Aye, I tried fixing my bumper with JB Weld but it eventually gave away for some strange reason. For my second repair attempt I am going to be using both hardware and adheasive, so what kind do you suggest I can pick up?
Old Jun 15, 2005 | 12:49 PM
idriveadelsol7's Avatar
Default Re: Adheasive better than JBWeld (Paprika)
jb weld is strong as hell... the only reason it probably wouldn't work is because it does not bond well to the material you apply it to. try using fiberglass... it works on polyurethane i think.
northkai3's Avatar
i think jb weld is primarily meant for metal there is a really good glue called gorilla glue i would try that
Old Jun 15, 2005 | 12:53 PM
Apocolipse269's Avatar
gorilla glue
Its good for small applications though, not really big ones
Old Jun 15, 2005 | 08:08 PM
Paprika's Avatar
My gosh, any other ideas people?
Old Jun 15, 2005 | 08:18 PM
Aphelion's Avatar
Default Re: (Paprika)
I'm not sure what part of your bumper you cracked or how bad it is...
I was into r/c airplanes for a little while, and had a thing called CA glue. You could put the glue between two pieces of plastic, spray it with quick-set formula, and literally 1 second later it was bonded. It's like super glue, but stronger and sets in a second. One time I had a broken prop (plastic) and no spares, so I glued the prop together using CA glue, and to my and everyone else's surprise, the prop stayed together in flight - where it experiences not only extreme centrifugal forces, but also side forces from dives and climbs. Overall very amazing stuff, you can get CA glue and quick-set at any r/c hobby shop.
Old Jun 15, 2005 | 08:20 PM
Luserkid's Avatar
Default Re: (Aphelion)
What exactly is wrong with the bumper?
For my crack i used fiberglass then bondo to smooth it out.
Old Jun 15, 2005 | 08:29 PM
EK k kay's Avatar
Default Re: (Luserkid)
JB weld sucks for plastics. I tried it on my cracked abs lip and it just cracks again with ease.
TheIVJac|{al
Jun 7, 2010 02:29 PM
94WhtTeg
Paint and Body
Sep 18, 2009 08:38 AM
97BB6Type-SH
Oct 25, 2006 06:40 PM
TurBoTeG
Apr 13, 2003 09:00 AM
TwistedSI
Apr 6, 2003 05:34 PM
