Rod bearing crush?
Old Jun 15, 2005 | 10:14 AM
b16hybridsol's Avatar
Default Rod bearing crush?
i'm in the processofbuying a bottom end, but ups won;t ship over 150 so he has to take rods/pistons out and ship them seperatly. This is a fresh motor, never ran polished crank etc..
Question is once the torque is taken off the caps then the bearings are already crushed. So do I need to buy new rod bearings because they won;t have the same crush fit once they go back together, or will they be alright
Old Jun 15, 2005 | 01:32 PM
tgreaves's Avatar
Default Re: Rod bearing crush? (b16hybridsol)
They will be fine.. Just remember to put some assembly lube on the bearings when putting it together..
Old Jun 15, 2005 | 02:42 PM
civicross's Avatar
Default Re: Rod bearing crush? (tgreaves)
Make sure they all go back on the same journals they started on.
Old Jun 16, 2005 | 01:37 PM
Default Re: Rod bearing crush? (civicross)
How about mains?
Old Jun 16, 2005 | 02:13 PM
civicross's Avatar
Those as well.
Old Jun 16, 2005 | 04:54 PM
FERIOkid's Avatar
make sure everything is extremely clean especially in the backside of the bearings. one stop that is not clean will create a hot spot and cause uneven wear on your bearing. Good luck
Old Jun 16, 2005 | 04:59 PM
Default Re: Rod bearing crush? (slowdx9585)
thanks guys
Old Jun 17, 2005 | 04:21 PM
FERIOkid's Avatar
anytime
n/a_kong
Jul 2, 2010 06:52 AM
computer07
Mar 3, 2009 08:26 PM
sixtodc4
Jan 20, 2008 09:33 AM
v4lu3s
Jul 26, 2004 11:25 AM
BeerMan
Aug 31, 2003 06:22 PM
