How do you properly disable the airbag?
Old Jun 15, 2005 | 09:36 AM
bmw626's Avatar
Default How do you properly disable the airbag?
I searched but i couldn't get any specifics. I need to disable my airbag and I am stuck (outside working on it now, wirelessly )but i have the red connector but idk what to do with it. please enlighten me, thanks
Old Jun 15, 2005 | 09:37 AM
Relic1's Avatar
Default Re: How do you properly disable the airbag? (bmw626)
year, model?
Old Jun 15, 2005 | 09:38 AM
bmw626's Avatar
Default Re: How do you properly disable the airbag? (Relic1)
1995 EJ1
Good ol' Screwtape's Avatar
Multi-paradigm
i just started diconnecting things that lead to the airbag on the steering wheel. it's pretty simple.
Do you just want to disable the airbag? Or are you trying to remove it altogether to make way for a steering wheel swap?
Old Jun 15, 2005 | 09:41 AM
bmw626's Avatar
Default Re: How do you properly disable the airbag? (Screwtape:)
i need to take it out and check out all my wiring cuz my horn and cruise control are both disabled and my srs light is on... and no, i am not going to just start disconnecting things
Old Jun 15, 2005 | 09:45 AM
DC4_MADMAN's Avatar
Disconnect battery, and wait 20-30 minutes for it to dissable. Should be ok from there to remove. I am not responsible for anything that happens(disclaimer), but this is how I did it on mine.
Be VERY careful handling that thing.
Old Jun 15, 2005 | 09:48 AM
bmw626's Avatar
Default Re: (4door_demon)
****, i dont want the thing to go off on me, that will **** me off
bmw626's Avatar
I am suppose to do something with the red connector, i just dont know what.
Old Jun 15, 2005 | 09:53 AM
gabebauman's Avatar
Can't you just remove the fuse under the dash? SRS fuse?
Old Jun 15, 2005 | 09:55 AM
bmw626's Avatar
Default Re: How do you properly disable the airbag? (gabebauman)
I would think there is a capacitor or something in the airbag still, but idk, i am not that smart with civic yet
Old Jun 15, 2005 | 10:00 AM
DC4_MADMAN's Avatar
Fasten together the red short connectors found by removing steering whell access panel. Then disconnect the 3 pin connector between the airbag and cable reel and attach the short connector to the airbag side of the connector.
This is done AFTER disconnecting the battery and waiting for 20-30 minutes.
Out of my Chilton manual.
Disclaimer still applies.
Old Jun 15, 2005 | 10:02 AM
gabebauman's Avatar
Default Re: How do you properly disable the airbag? (4door_demon)
More info: http://importnut.net/civicsteeringswap.htm
Old Jun 15, 2005 | 10:09 AM
Relic1's Avatar
I've had my airbag out three times now, never once disconnected the battery. Last time I was listening to the radio while I did it.
Just don't do anything stupid while you're working and you'll be fine.
disconnect the plug to the airbag and plug in the red jumper and it's safe until you reconnect it.
no horn, no buttons and SRS light, sounds liek the ground is gone from the wheel. Make sure it's not the connection in the car that's doing it before diving into the wheel.
apm
Apr 10, 2009 09:00 AM
niceprelude
Dec 11, 2008 05:05 AM
spooneg8
Dec 18, 2006 12:58 AM
GReddyTurboCoupe
May 23, 2005 01:44 PM
NL-Vtec
Sep 29, 2004 09:32 PM
