b16 5th scrape
Old Jun 15, 2005 | 06:26 AM
sethman88's Avatar
Default b16 5th scrape
I finished my b16a swap last weekend. I got the swap, mounts, linkage, vtec subharness from hmotorsonline. Everything is great although i did have to change the axles. they were clicking bad. When it is cold, it will sometimes scrape into 5th but no other gears. could it be anything else besides the sincro's? linkage is hooked up properly and fluid is full. http://www.cardomain.com/ride/834818 here is a link with pics.
Old Jun 15, 2005 | 08:01 AM
ButterMule's Avatar
Default Re: b16 5th scrape (sethman88)
i had the same sort of problem inmy b16 and this is what i did. I went to a local gm dealer and bought some GM synchromesh for $10 a bottle and put it in my tranny, after about 500miles the grind was completely gone. GM synchromesh
Old Jun 15, 2005 | 08:30 AM
InJ3cted's Avatar
Default Re: b16 5th scrape (ButterMule)
what kind of trans fluid are you using?
Old Jun 15, 2005 | 08:33 AM
SiR Inspired ED7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ButterMule &raquo;</TD></TR><TR><TD CLASS="quote">i had the same sort of problem inmy b16 and this is what i did. I went to a local gm dealer and bought some GM synchromesh for $10 a bottle and put it in my tranny, after about 500miles the grind was completely gone. GM synchromesh </TD></TR></TABLE>
actually it costs 5 bucks a quart. it worked for me when i had 2nd gear grinding at high rpm's...
Old Jun 15, 2005 | 08:53 AM
BoostedA6's Avatar
Default Re: b16 5th scrape (88 Crx Si)
I don' know what it is about these types of GM products but the GM E.O.S. (engine oil supplement) is great stuff too! Haven't used it on any of my Honda's but it worked miracles on my Ranger. Sorry for the off topic.
Old Jun 15, 2005 | 10:30 AM
sethman88's Avatar
I am using castrol 5w30. Thanks guys.
smokez187
May 4, 2007 10:59 AM
em2ssm02
Jul 7, 2006 11:53 AM
sol_1320
Jul 16, 2005 09:33 PM
98gsrTEG
Apr 3, 2005 08:11 AM
