VIN info
Old Jun 15, 2005 | 06:01 AM
SamK's Avatar
Default VIN info
I have a VF500 which is an unofficial import in the UK. Does anybody know where I can find out the exact model and year of manufacture from the VIN or chassis number?
Old Jun 15, 2005 | 01:38 PM
cbrman's Avatar
Default Re: VIN info (SamK)
There should be a sticker on the frame that clearly states the year as well as the vin. If you know which state it was last titled in you could check to see if the dmv has an online vin search. (Florida has a free one on the state's dmv website and it tells basically everything but damage history.)
Good luck.
Steven
Old Jun 15, 2005 | 02:32 PM
rastropovitch
Guest
Posts: n/a
Oooooo... you know those little VF's catch fire right? I rememebr a few of them catching fire back in the day after they had been out for a couple years, seems as though if they are tipped over they can ignite. they run great while upright though.
http://www.vfrdiscussion.com/
Also, V-4 Honda's, almost all of them made before 1985, have a terminal case of improperly hardened camlobes that cause the surface of them to erode. The result is a very noisy, self-destructing engine. The cure is expensive, cams and rockers at least. A valve inspection would determine if this is what's happening to your bike. Just lift the front cam cover as it's the easiest to get to, and inspect the lobes on the two visible camshafts. If it looks like termites have gotten to them, they're shot.
Modified by MSchu at 3:43 PM 6/15/2005
Old Jun 16, 2005 | 12:01 PM
Lewdin' Incognito's Avatar
I've got carfax for the next 30 days if that would help......?
Old Jun 17, 2005 | 12:57 AM
SamK's Avatar
These are the labels on the frame -
The bike has kph clocks so is most likely European market. The headlight has been changed for UK (ride on the left).
Old Jun 17, 2005 | 07:22 AM
rastropovitch
Guest
Posts: n/a
more than likely it is canadian
Blindstuff
Honda Motorcycles
Nov 11, 2008 07:33 PM
kayelemenohpee
24
Sep 10, 2007 08:10 PM
BRICKHEAD
Honda Motorcycles
13
Mar 2, 2005 08:36 AM
BeanRacer
Apr 17, 2003 12:25 PM
