S2000 ecu in a RSX Type S
Old Feb 11, 2002 | 08:49 AM
RevIllusions's Avatar
Default S2000 ecu in a RSX Type S
i had heard a rumor that a s2000 ecm will plug into a rsx type s......can anyone verify???
since they are both 2.0 liters......are there any advantages to that?? optimal fuel mapping for instance???
rumor has it thet it does plug in and with a i/h/e combo produces high HP gains.....
Old Feb 11, 2002 | 09:54 AM
ThePunk's Avatar
Default Re: S2000 ecu in a RSX Type S (EF8 B18C)
I highly doubt that it would be a "plug and play" deal..
Keep in mind that that would also raise the revlimiter past safe levels for a stock RSX motor.
Old Feb 15, 2002 | 12:49 PM
ITR00-816's Avatar
New User
The S2000 engine is VTEC and the RSX TypeS is I-VTEC...The plug may fit but it won't work....
George
Old Feb 15, 2002 | 03:44 PM
EG8R's Avatar
Default Re: S2000 ecu in a RSX Type S (ITR00-816)
BWAHAHAHAHAHAHA
Old Feb 15, 2002 | 04:52 PM
f1nal zeros's Avatar
well im pretty sure it would be hard to make them work, cuz the s2ooo is vtec and the rsx-s is ivtec, it might work, but then again., it might just mess everything up. my crew member has a s2ooo. i'll look at them both and see whats up. if it works then hell yea. but first i will check into them both. that would be sick to see a rsx-s with a spoon s2ooo ecu, hahaha. all i can say it rev to 11ooo!!!!!!
Old Feb 15, 2002 | 07:47 PM
ITR00-816's Avatar
New User
Default Re: S2000 ecu in a RSX Type S (f1nal zeros)
If you believe that is the ECU that limit an engine to spin up to 11,000rpm...What can I say, why stop at 11,000, it is just a chip, go to 25,000 rpm...
Just let me know the results!!!
George
Old Feb 15, 2002 | 07:59 PM
whoops. i completely forgot, hehe my bad. i noe the spoon s2ooo can rev to 11ooo. haha i forgot. ecu/engine are both needed to get it to 11ooo. my bad, thanks for the reminder =]
Old Feb 15, 2002 | 08:05 PM
f0de's Avatar
..the rev limiters in the ecu.. what you guys talking about.. i have a spoon ecu for my h22a with no rev limit.. and its been over 9k on a stock h22a.. not mine mind you :]
Old Feb 15, 2002 | 11:06 PM
Nick M's Avatar
Default Re: S2000 ecu in a RSX Type S (f0de)
9k on stock H22 rods? Thats just asking for trouble. The rod ratio is pretty bad for high revs.
Old Feb 19, 2002 | 10:01 PM
AJ PwR's Avatar
I assume they have same plugs but for sure they run different programs so don't bother.
disboibdavid
Honda S2000
41
Nov 6, 2007 06:45 PM
Dc-5...attacK
Honda S2000
59
Aug 27, 2006 01:13 PM
97ShLude
Honda S2000
Apr 10, 2005 07:44 PM
