Collapsing Craters?
Old Jun 15, 2005 | 03:10 AM
Want2race's Avatar
Default Collapsing Craters?
On the odd occasion I lay out a descent bead and all of a sudden the entire bead almost collapses into a crater like line.
Anyone know what causes that ?
Old Jun 15, 2005 | 04:45 AM
WYLDE's Avatar
Default Re: Collapsing Craters? (Want2race)
Try using less amps.
Old Jun 15, 2005 | 06:23 AM
david@didrace.com's Avatar
Base metal? Filler metal? Mig, tig, stick? Shielding gas?
Old Jun 15, 2005 | 07:17 AM
Want2race's Avatar
Default Re: Collapsing Craters? (backpurge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge &raquo;</TD></TR><TR><TD CLASS="quote">Base metal? Filler metal? Mig, tig, stick? Shielding gas?</TD></TR></TABLE>
Mild Steel 16ga Filler is Copper 6071 I think.
Mig with 25/75 Gas
Old Jun 15, 2005 | 12:02 PM
Copper filler would be your problem.
No, umm, ER71 is a fine filler for mild steel. You're gas is ok.
What are the dimensions of the base metal? Are you 100% sure the base metal is mild steel?
Old Jun 16, 2005 | 06:49 PM
Want2race's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge &raquo;</TD></TR><TR><TD CLASS="quote">Copper filler would be your problem.
What are the dimensions of the base metal? Are you 100% sure the base metal is mild steel?</TD></TR></TABLE>
base metals mild steel.
ER71S i believe is the wire I am using.
It is 100% mild steel
Old Jun 17, 2005 | 06:39 AM
Perhaps you're not cleaning it enough and getting porosity on the inside of the weld.
boongley29
Acura TSX
25
Sep 19, 2007 01:52 PM
tigueremalo
Feb 5, 2007 08:00 AM
JDM_EK_JOE
Feb 12, 2006 05:26 PM
suffe
Jun 23, 2005 07:58 AM
xunkn0vvnx
Mar 30, 2005 05:33 PM
