98 v6 with 105k maintenance
How long since you bleed brakes? Fresh fluid every 2 years is good. Every 3 years is sorta mediocre. If it's original (7 years?) you're overdue. Same for anti-freeze.
Might be a good excuse to do a good examination of lots of stuff:
Vacuum hoses - getting old & brittle?
Brake calipers - pads getting thin & caliper pins sticking?
Suspension - balljoint rubber boots OK? Anything loose?
Axles - rubber CV joint boots OK?
Fuel & brake lines under car - getting rusty??
usually all of your required maint like timing belt trans fluid, inspections, etc will fall on the time time frame there are some things you do every 15K, 30K, 45K, 60K, 75K,90, 105K, etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teler86 »</TD></TR><TR><TD CLASS="quote">i've never heard of bleeding brakes every 2 years
</TD></TR></TABLE>Honda seems to put that in based on miles. I bet it's in your manual, maybe every 40k.
I like to do it based on time, since brake fluid keeps absorbing moisture no matter whether you drive or not.
</TD></TR></TABLE>Honda seems to put that in based on miles. I bet it's in your manual, maybe every 40k.I like to do it based on time, since brake fluid keeps absorbing moisture no matter whether you drive or not.
From: living too close to Karl, everythings busted, nc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">Honda seems to put that in based on miles. I bet it's in your manual, maybe every 40k.
Owners manual recommends 45,000 miles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">I thought it was every 45,000 miles or three years.</TD></TR></TABLE>OK, well then he should have already done it twice...
I mentioned it because lots of people don't even know about it.
1yesfan
Sep 20, 2016 11:05 AM
Campee
Apr 2, 2003 09:32 AM
